Old 05-26-2003, 05:40 AM   #1
Aqua Angel
Default project is now starting
Well, finally got a job that pays me well and already savings are growing for my sweet Angel.
Parts are on there way and soon will buy my PIAA 3000 light system $532.00.
parts ordered:
Tubo centre tail light - $150.00
front grill and front light surroundings - $75.00
window mechanism X 2 -$ 250.00
some interior parts - $60.00
remote engine start - $75.00 +TX
MP3 player deck -$400.00
Sub and amp -$500.00
paint job "$1.000.00" will be done in the next few months. i figured pearl color or mirror effect "chrome" And so much more is coming. Glad that i kept the car after all those bad luck with her.
and does anyone has ever installed hydraulic suspension on their Audi? i'm not talking about the jumping car kind of stuff, but you know, lower and rising the car for better traction in different driving condition?
if you did, how much does it cost to have those installed or where can i get them?
thanks
Angel O=)
Audi 84, 5000S - "Angel"
Things done to Angel:
Replaced everything but the engine , power steering rack and the BOMB. You name it, i have done it.
F I N A L L Y !!!! i can drive in peace
She is back on the road
Angel, BC, Canada
Aqua Angel is offline   Reply With Quote
Old 05-26-2003, 08:44 AM   #2
cuatrokoop
1990 Audi Coupe
My Garage
cuatrokoop's Avatar
Default Re: project is now starting
I'd just go with an airbag suspension. Less exense, less weight. You can get it from just a simple fill-it-yourself bag to a system controlled via dash switches.
My dad and I put an airbag "helper" setup on the rear of his Chevy van, installed in a couple hours and is of the fill-it-yourself variety. It was a couple hundred bucks I thought. The "cockpit controlled" systems, especially 4-wheel systems, are a lot more as they require an onboard compressor and tank. When you do the conversion, you'll want to get different shocks/struts/inserts/dampers that will work better with the variable ride height. Bilstein and Koni make dampers that work well with variable ride heights...figure $150+ per corner for those dampers.
http://coupe.gofergusons.org
"SECRETARY OF ENERGY AND AE ASSWHIPPINGS:
We call him when we need a big plane that kills people."
cuatrokoop is offline   Reply With Quote
Old 05-26-2003, 01:33 PM   #3
Tom Faust
Default Air suspension is all the rage with Hot Rods now
There are several companies in the business now, mostly geared to pre-war Fords. Do a search on Google for "air suspension". There is also a compay named "Bagmaster" their specialty is Lincolns, but Lincoln is the only car I know of that came with front air struts. Most air bag systems simply replace an existing coil spring with an air bag, using the same perches. Air "helper springs" in each corner might do it. Not sure how they would mount in the front. If you want it on board, Lincoln compressors are $140.00 rebuilt, next to free in junkyards. Do a Google search for "Lincoln MK VIII air suspension" that should find the struts, I have no idea if they could be adapted. A MK VIII weighs about the same as a Quattro at about 3600 pounds. That is within 100 pounds of a fully equipped Quattro. The Lincoln is only about 3" longer, don't know if that matters.
Tom Faust is offline   Reply With Quote
