Old 05-22-2003, 02:00 PM   #1
selfproclaimedv8buff
Default Changed both engine mounts last night! found more problems ...
both of my tranny mounts are GONE! I gotta change them! i started at 11:30 at night and didnt' finish till 2:00 in the morning! had to get it done! She feels real nice now!
so are tranny mounts easy/hard? Any BTDT's?
1990 AUDI COUPE QUATTRO(5lug)
1995.5 AUDI S6 AVANT
1981 VW Caddy (dd duties)
1992 AUDI V8 QUATTRO SOLD
selfproclaimedv8buff is offline   Reply With Quote
Old 05-22-2003, 02:46 PM   #2
Will Ng
Member
Default What symptoms for bad engine mounts?
How did you check them?
I'm trying to figure out if I'll need to do mine as well.
TIA.
R.I.P.
<A HREF="http://members.fortunecity.com/willng/my_audi_200/manual/index.htm">
88-91 Audi 100/200 Factory Service Training Manual</A>
Will Ng is offline   Reply With Quote
Old 05-23-2003, 01:51 AM   #3
shortyq
Default Re: Changed both engine mounts last night! found more problems ...
The trans wings are fairly straight forward. The left side is a piece of cake. The right side is a bit tighter, and you need to remove the heat shield that covers it (3 8mm wrenched screws), and the cat is really close to it, but both sides can be done in car without removal of other components.
HTH
Scott Justusson
shortyq is offline   Reply With Quote
Old 05-23-2003, 02:20 AM   #4
shortyq
Default Re: What symptoms for bad engine mounts?
Bad mounts come from age and heat cycles next to a hot turbo... First ck to see how close the pan is to the subframe. The pan should sit level at the back, a bad RSMM will list to the Pass side. Or,just pull off the 2 15mm nuts holding the MM to the subframe, a bad motor mount will drop the cup into your hand. Also, funny exhaust noises during on throttle application and leaking exhaust studs are both results of bad right side motor mount.
HTH
Scott Justusson
Old 05-23-2003, 05:30 AM   #5
cbpldc
Junior Member
Tranny mounts are easy. Of course, my subframe is laying on the floor, so it's 2 bolts per and they're out.
Chris
cbpldc is offline   Reply With Quote
Old 05-23-2003, 06:14 AM   #6
cuatrokoop
1990 Audi Coupe
My Garage
cuatrokoop's Avatar
Yup...The only problem with the pass. side mount is that shield doesn't always want to come off w/out some mechanical coaxing (rust). I actually left the shield in place on the '86, just bent it "a bit" for tool clearance.
http://coupe.gofergusons.org
"SECRETARY OF ENERGY AND AE ASSWHIPPINGS:
We call him when we need a big plane that kills people."
cuatrokoop is offline   Reply With Quote
audi, bad, engine, mounts, problems, quattro, v8
