#1 | ||
#2 |
My '90 has a similar prolem. There is a rod actuator from the lock. It is is held by a plastic anchor. It was such a job to get at I gave up and just lock from the passenger's door. I got a deal on that car because the ignition kill was part of it, seller thought it wouldn't run.
#3 |
I ageree with Tom Faust, it sounds like the rod connector to the key lock is broken. Suggest that you remove the door panel so that you can look at the problem. Or better yet,you should be able to just remove the screws that hold on the door handle, jently pull back on the door handle to see if the two rods are connected to the door handle. If you don't see that the two rods are connected, you have found your problem. I am assuming that this is on your '87 5K? I have done this on my '86 5K a couple of times, so I know that this works. Regards, Rooster
