Old 04-23-2003, 02:07 AM   #1
maca
Default The needle of the speedometer oscillate....
hi all,
i had the problem with the speedometer needle.
it doesn`t show the right speed.
the problem was a cold solder joint in the platine behind the speedometer.....
greeting from europe, austria
arthur
maca is offline   Reply With Quote
Old 04-23-2003, 05:45 AM   #2
paulfern2000
Default Howdy Arthur...
welcome to the North American type44 forum first of all.
About the needle ...do you have a series 1 or series 2 type44?
SERIES 1 (AUDI 5000/ 100/200) 1982-1987
SERIES 2 (AUDI 100/200) 1989-1991
the series one had the cable driven speedo which would do this when the cable got week or rusted..
I have never heard about it one a series two though...
Paul
Paul Fernandes
luxembourg-Europe
1991- Audi V8 5 speed
1991- Audi 100-C4(everyday car)
1990- Audi 100 avant sport quattro turbo
1990- Audi 100 avant quattro (in restoration)
paulfern2000 is offline   Reply With Quote
Old 04-23-2003, 08:55 AM   #3
Will Ng
Member
Default Solder joint problem will return...
I also had this common annoying problem with the 100/200 type44 electronic speedometer.
The joint will eventually break again from vibration.
I replaced the 4 rigid pass-thru pins with wires.
I routed them from the inner circuit boards to the exterior and soldered them to their destinations on the outer board. Thus, the connections are now immune to vibration.
The problem hasn't returned.
R.I.P.
<A HREF="http://members.fortunecity.com/willng/my_audi_200/manual/index.htm">
88-91 Audi 100/200 Factory Service Training Manual</A>
Will Ng is offline   Reply With Quote
Old 04-23-2003, 10:38 AM   #4
maca
Default Re: Solder joint problem will return...
hi will,
yes, a realy known problem. by the way when i repared these connection i soldered also the other solderpoints of the circuit.
you tod it, the mainly problem is the vibration.
regards arthur
Old 04-23-2003, 10:43 AM   #5
maca
Default series 2
hi paul,
my audi is a serie 2 car with a NF engine (100kW)
there the speedometer is not driven by a cable.
the problems are broklen solderpoints at the circuite. will posted it allready...
regards arthur
Old 04-23-2003, 11:30 AM   #6
maca
Default red backlights...
hy paul,
i am waiting so hard for the red backlights with bigger moulds (53cm) for my audi avant.
do you just know when these parts are available?
regards arthur
Old 04-23-2003, 01:09 PM   #7
200TQROCKIES
Default need advice
i have the same problem, i'll attemp to fix it soon, is there "what ever you do, don't ...", so that i wouldn't break something permenantely. Also never took the instrument cluster out before, any advice?
Thanks
200TQROCKIES is offline   Reply With Quote
Old 04-23-2003, 05:08 PM   #8
4Driver4
Tech Guru
4Driver4's Avatar
Default Try this.
4Driver4
"Never give up the throttle until the bitter end." -RC
2003 Mini Cooper S (Fun!)
1995 Mazda Miata: the anti-Audi
1999 Mazda Miata SSB: track beotch
2003 GMC Yukon Denali XL: the anti-earth
2004 Dodge Dakota: hey, at least it's stick and 4x4
Old 04-23-2003, 09:31 PM   #9
200TQROCKIES
Default thanks
i talked to scott even ordered the bulbs(very nice guy), since couple of mine are don't work. He told me that with seat heaters, usually actual seat heaters go. Which makes me sad because i don't have tool to test it.
thanks for the direction.
Old 04-23-2003, 10:12 PM   #10
paulfern2000
Default Re: red backlights...
The 53cm units will be avaialble in about two months...still allot of work to go on them...
About your speedo ...ah! the solder points...
a very week point on the type44 cars..I have this problems on my dash board as well but not related to the speedo..also a solder problem as well.
Paul
Paul Fernandes
luxembourg-Europe
90, audi, cold, electronic, miata, needle, oscillate, oscillates, oscillating, point, quattro, soldering, speedometer, speedometeroscillate, v8, vibrating, woes
