What does a bad wheel bearing do?? Is it dangerous to drive with a bad bearing?
Old 04-29-2002, 07:04 PM
Senna4Life's Avatar
Old 04-29-2002, 07:32 PM
cuatrokoop's Avatar
Default Re: What does a bad wheel bearing do?? Is it dangerous to drive with a bad bearing?
makes noise (some at first, then more, and more, and more, until you cook the bearing enough that it locks the wheel in question up). how much noise is it making?
Old 04-29-2002, 11:59 PM
Junior Member
crotext's Avatar
If you are getting any squealing or grinding noise from the wheel in question, then park it until you know what it is for sure. Rock caught in the brakes? A wheel bearing going out only gets worse until it locks the wheel and gets very expensive. Put it on blocks and check it good.
Old 04-30-2002, 12:34 AM
SteveAngry's Avatar
Default Keep driving with a bad...
wheel bearing and soon you will wreck the hub. Then you will not only have to pay for a wheel bearing kit, but you will also have to buy a new/used hub...
Steve
Michigan
Old 04-30-2002, 06:46 AM
Senna4Life's Avatar
Default RE: how much noise is it making?
Well...when driving straight it moans, (you can hear it, my friends tell me it sounds like an airplane) but if I turn the wheel a little to the left while still driving a little straight the noise goes away. If I let the wheel be straight again it comes back...
Thanks
Old 04-30-2002, 09:12 AM
Junior Member
the red pill's Avatar
You're fortunate you can get your sound to go away. Mine thumps whenever the car is moving now, it got progressively worse in the past week. I'm going to check it for sure today to make sure it's the wheel bearing before I shell out money I don't have for a new one.
Old 04-30-2002, 01:02 PM
Audi200tq's Avatar
Are you sure it's a bearing and not a CV joint? Bearings usually howl at all times, whereas the noise from a worn CV is sometimes steering-input dependent.
fshik
1.8T Discussion
01-30-2008 04:42 PM
Mr Paul [T-28]
11-14-2006 09:41 AM
audijim113
10-22-2004 08:04 PM
oggie_s
05-24-2003 09:00 PM
OneEighth
05-15-2002 11:05 PM
Quick Reply: What does a bad wheel bearing do?? Is it dangerous to drive with a bad bearing?
