Old 08-14-2001, 07:26 AM   #1
Power5
Junior Member
Default First time in here, one quick question.
What turbo can I put onto a 10v Turbo to get up to around 300bhp with all the normal goodies. Chip, exhaust, what ever intake is available, possibly cams?
Thanks for any info. =)
-AARON
Aaron
Cincinnati, OH
2001 TT 225 blk/blk(13.6@98mph w/1.7 60') 3" CB with Flowmaster and H&R Coilovers
1992 Passat Wagon aka: the draggin wagon
Power5 is offline   Reply With Quote
Old 08-14-2001, 07:53 AM   #2
1 slow Audi
Default Re: First time in here, one quick question.
this is a K26 with 15 degree clip on the turbine and a TO4 48-57 trim compresor wheel with a modyfied compresor cover. the cover has a 3"inlet and is modyfied to flow the extra air. This turbo is a bolton exept the inlet wich changes from 2" to 3".
1 slow Audi is offline   Reply With Quote
Old 08-14-2001, 08:04 AM   #3
Power5
Junior Member
Default Will that work on the 10v
There product guide is not working. How much should that cost.
BTW nice freakin engine man. That thing must haul.
I'm looking for a 10v turbo engine also. Happen to know where any good ones are.
Thanks for the info
Aaron
Cincinnati, OH
Old 08-14-2001, 08:23 AM   #4
1 slow Audi
Default Re: Will that work on the 10v
that is a 10v turbo
that turbo is around $1400-1600 cdn
that turbo is good to about 450-500hp
where are you located?
Old 08-14-2001, 08:56 AM   #5
Power5
Junior Member
Default Wow 450
I'm in cincinnati ohio. I thought that picture was the turbo. I'm thinking a little less pricey though. Around 300hp "only". Not trying to make a rocket ship. =)
How difficult is a 10v turbo into a '88 90 5cyl FWD. If you have any knowledge on that subject.
Aaron
Cincinnati, OH
Old 08-14-2001, 09:39 AM   #6
1 slow Audi
Default Re: Wow 450
It is only $900us thats cheep(you wana play you gota pay)
I know few people that done it and it is straight forward it is not hard the motor bolts on and the mouts bolt on to the motor the harnes is a pain but its not that bad.
Old 08-14-2001, 10:59 PM   #7
turbobmwkiller
Default Re: What a beauty ,Radim
Nice car indeed,perhaps you have some ideas on how to improve the reliability of the auto transmission on turbo auto.Will fitting a transmission oil cooler help?
turbobmwkiller is offline   Reply With Quote
Old 08-15-2001, 01:35 PM   #8
SteveAngry
Default Audi automatics already have a...
ATF cooler. Perhaps you were thinking of adding a larger one? Seems like the factory one does an OK job. Most of those Audi tranny's fail from seal failures between the diff and tranny not from overheating of the fluid...IMHO.
Steve Ankney
88 5000
Holland, MI
1998 A6q
1986 5ktq: Megasquirt EFI and a lot of other mods your car probably doesn't have...
SteveAngry is offline   Reply With Quote
Old 08-15-2001, 09:01 PM   #9
turbobmwkiller
Default Re: Thanks Stephen ..........how often should you change it?
Thanks Stephen,my car's atf goes to the bottom of the engine radiator it does not have separate cooler.Can you tell me how yours is connected?How often should I change this seal between the diff and gearbox?
Old 08-19-2001, 07:29 PM   #10
SteveAngry
Default Unsure of...
a timetable on changing out that seal between the diff and the tranny. Theres probably a TSB out there on this I'd imagine. IMHO if your car is nearing 100K miles or over 10 years old I would plan on doing it soon if you want to keep the tranny going...
If not, just keep changing the tranny fluid every year and monitor the fluid level to make sure that it's not getting overfilled due to the diffential fluid getting past the seal and mixing in...
HTH!
Steve Ankney
88 5000
Holland, MI
1998 A6q
