Go Back   AudiWorld Forums » Audi Models » Audi Original "S" Cars
Old 04-09-2008, 09:35 PM   #1
popdemonic
Default 2B camber plate experiencing some noisy...
Seem that the 2B camber plate causes some noisy sound when the car did knock on the abrupt sudden impact.the sound is just like the something bumping on the metal.Is this normal?
the 2B is working silent with the small irregularites road or small potholes.
I havn't removed the metal cap for the stop buffer yet.Thinking to remove it.Hope it will help.Had anuone experinced this before?
popdemonic is offline   Reply With Quote
Old 04-09-2008, 09:50 PM   #2
MiniMan
Default I get this same noise. Not sure if its normal or not... sure is annoying though.
Corey
Edmonton, AB, Canada
1993 Audi S4 (178k miles) - Pearl on Black Leather with CF Trim
Wheels:
Simmons FR18, Custom Painted Audi Pearl White Faces, 18x8.5" front, 18x9.5" rear - 255/35/18, Spacers, Extended wheel bolts, Audi Bolero 17x8 winter wheels
Suspension:
H&R Springs, Revalved Bilstein Sport Struts, 2Bennett Revolution Camber Plates, Front Strut Tower Bar
Engine:
Garrett GT30/40R Turbo w/ 0.82 AR and 4" Inlet, LoveFab Tubular Manifold, Custom made 034 Downpipe, QTEC Electric Exhaust Dump Valve, 7A Exhaust Cam, 60lb/hr High Impedance Injectors, Bosch 044 Fuel Pump, 24.5x9.5x3.5 Dave Stone FMIC, Samco Hoses, Stromung RSS Turbo Back 3" Exhaust, Tial 44mm Wastegate, 034 Custom Modded Motronic ECU, Javad Shadzi Tune with 91 and 100 Octane Programs, 4 Bar Pressure Transducer, 3-5 Bar Adjustable FPR, 4" AEM Air Filter, Custom made 4" Intake, ARP Head Studs, RS2 Rod Bearings, Forged Eagle Rods, Titanium Valve Retainers, High Rate Valve Springs, Compression Dropping Multilayer Steel Headgasket, 034 Fuel Pressure Gauge, Custom fuel lines
Drivetrain:
Audi B5 S4 6 speed, SPEC Stage 3+ clutch kit, Fidanza 10lb flywheel, 034EFI Short Shift Kit, Heavy Duty S6+ Transmission mounts, 034EFI Dense polysnub mount with bracket
Brakes:
Porsche 996tt Calipers, Porsche 993tt 2-Piece Drilled Rotors, Textar Brake Pads, BIRA Hats, ECS brackets, Stainless Steel Brake Lines
Cosmetics:
Carbon fiber hood, Carbon fiber trunk, Euro S4 one piece rear bumper, Euro S6 PLUS center tail light section, LLTEK RS lower valence, Slatted Front Bumper and Rebar, OEM trunk spoiler, HID conversion kit (6000K), PIAA Fog Lights, Clear front turn signals, 20% window tint
Interior:
A pillar 30 PSI boost gauge, Pioneer Premier AM/FM/CD/MP3 DEH-740MP, JL Audio 4 x 100 amplifier, Diamond Audio 5.5" w/ tweeters, Diamond Audio 6"x9" speakers, 2 Watt dash lights
1969 Mercedes-Benz Unimog 421 (40k miles) - U45/U600, hydro winch/3pt hitch/tipper box, onboard air, 8 forward 8 reverse speeds, etc.
1991 Mitsubishi Pajero (68k miles) - 2.5TD, LWB, Roof rack, DD
1991 Toyota 4Runner (unknown miles) - 4.3 Chev swap, Dual T-cases, ~12" lift, locked and armored
2000 Yamaha R1 (14k miles) - Piped, flush front signals, chopped undertail, jetted to 130 WHP, +1 front, -2 rear
MiniMan is offline   Reply With Quote
Old 04-09-2008, 10:46 PM   #3
popdemonic
Default Corey,Had the noise come out since it brand new?
It've just installed the camber plate 3-4 days ago.I'm not sure if the noise came from the bearing.I've also STFA.WVURS6 said,the older version which polluted the noise will be came up
with older style of "2B" with oval around,larger logo . The latest Revolution will be came up with nwer "2B" style without oval,smaller. I got the latest one. Which one did you on your car,Corey?
here's i think it's from SchwarzS6
here's it's mine
Old 04-10-2008, 06:16 AM   #4
Herr Schröder
Herr Schröder's Avatar
Default I had it on my old car too; moved the suspension to Cody's car = silent. Kinda weird..
I don't know if it was the original installers or what happened, but it was a hollow clunk, like the sound of a blown up ball joint, of which the car didn't have.
Schroeder
"Modding stops when the dyno reads 1,000 and the ATM does not"
'92 S4: Built By Dave Jones of S-Line Motorsports: 400+WHP, 400+WTQ, 28lbs of Boost, 91 Octane
'95.5 UrS6 Avant: Pearl White and the bone stock daily driver (well kinda ;-).
Herr Schröder is offline   Reply With Quote
Old 04-10-2008, 09:15 AM   #5
WVUrS6
1995 Audi S6
Default Pop, you got the new bearings.
I have not had a single noise from my 2B set since I installed the newer style bearings so you may have some other suspension stuff going on or you may be one unlucky guy and gotten some bad bearings. The way you describe your sound is just like what mine sounded like when I had the old style bearings, they would knock on sudden abrupt impacts, especially on "washboard" pavement. (pavement with ripples in it).
You have the newer style bearings so I am surprised that they are knocking. Maybe the new bearings have brought to light some other weak component in your suspension. Ball joint, strut bearings, etc..
Do both sides knock?
2008 A4 2.0 S-Line Titanium
2007 Q7 4.2 S-Line
1995.5 S6
1990 V8 Quattro
WVUrS6 is offline   Reply With Quote
Old 04-10-2008, 09:26 AM   #6
WVUrS6
1995 Audi S6
Default It's not normal, you need the new bearings if your using the old style.
2007 Q7 4.2 S-Line
1995.5 S6
1990 V8 Quattro
Old 04-10-2008, 09:27 AM   #7
popdemonic
Default it's probably from the both side....
but mostly I heard from the driver side because
it's closed to us.the noise came out when it hit pretty hard and once(it sound like spring or s'thing like metal hitting).on daily driving,it's working silent.Had your old style bearing also caused the noise when the car running through the unsmoothed surface road?I've e-mail to Antoine@2bennett.com he hasn't replied me yet.I tried to lubed on the bearing seem doesn't help.I'm gonna remove the Cap for the stop buffer and reinstall the plate again.Hope it'll help
Old 04-10-2008, 09:38 AM   #8
WVUrS6
1995 Audi S6
Default Ohhh...does it only do this when you really compress the suspension?
If so you need to re-read the directions. You need to trim a portion of the fenderwell. This will only make a noise when you really compress the suspension as the top plate will smack the fenderwell.
If it is the bearings they will make noise with very little suspension compression, if the noise is only under suspension compression than I just solved the problem for you and re read the installation instructions.
The bad part is that this requires strut removal to do properly
2007 Q7 4.2 S-Line
1995.5 S6
1990 V8 Quattro
Old 04-10-2008, 09:59 AM   #9
popdemonic
Default WVUrS6,YGM.:-)
Old 04-10-2008, 11:34 AM   #10
WVUrS6
1995 Audi S6
Default YGM back!
2007 Q7 4.2 S-Line
1995.5 S6
1990 V8 Quattro
