Go Back   AudiWorld Forums » Audi Models » Audi Original "S" Cars
Old 02-17-2008, 08:16 AM   #1
Pedmaster
Default So I just pulled my codes finally...2111...what's the next logical step?
No start condition, when it last ran it ran great except toward the top at around 20 psi (MTM 1+) it would miss. Ignition switch is new so thats out, I could swear i don't hear the fuel pump prime though. Is that the next logical step?
Pedmaster is offline   Reply With Quote
Old 02-17-2008, 08:32 AM   #2
UrS4boy
UrS4boy's Avatar
Default 2111 code info from SJM's website.
2111 (Blink Fault Code), 00513 VAG1551/2 Fault Code Number
RPM sensor (G28)
Open or short circuit, sensor malfunction
Defective sensor & cables, metal fragments on flywheel teeth
Symptom: Engine will not start, misfires, may stop running
NOTE: I (Scott) have seen this fault code occur after cranking the engine during a no start condition
in a few rare cases where there was nothing wrong with the RPM sensor
Naturally, IMHHEO(tm),
Dave F. aka the Librarian
Car and Mods:
93 S4, 1.8t coil pack conversion (First in world using integral POS coil packs (??)), CF (OE), S6 steering wheel, RS2'd, Samcos, MRC, TDS-1, Apikol FMIC, Eibach/Bilstein, BIRA Sys 1, relayed FP
Click here to link to the UrS FAQ Thread Start
Uncle Dave says "You want my 'high horse, elitist' opinion ?(IMHHEO(tm))Then just post something stupid."
Unofficial Chief Cat-herder Vancouver UrS-car club
UrS4boy is offline   Reply With Quote
Old 02-17-2008, 08:36 AM   #3
UrS4boy
UrS4boy's Avatar
Default The UrS fuel pump does NOT prime with the key just "on".The ECU does not fire the J17 FP relay until
it gets a signal from the Cam Position Sensor (CPS).
Car and Mods:
Old 02-17-2008, 08:39 AM   #4
UrS4boy
UrS4boy's Avatar
Default 2111 might be real. Suggest swapping in a known to be good G28. Link inside
Car and Mods:
Old 02-17-2008, 09:24 AM   #5
Pedmaster
Default Why do all the forum archives say that when the engine isn't running above 28 rpms your going to
get the engine speed 2111 code anyway?
Old 02-17-2008, 09:30 AM   #6
UrS4boy
UrS4boy's Avatar
Default Because that is what the ECU is expecting. 28 RPM = approximate cranking speed during starting.
Car and Mods:
Old 02-17-2008, 09:38 AM   #7
UrS4boy
UrS4boy's Avatar
Default There are other "theories" on this.
Car and Mods:
Old 02-17-2008, 10:37 AM   #8
UrS4boy
UrS4boy's Avatar
Default And then there is the possibility that your crank position pin went AWOL. See inside.
Crank position pins have been known to just fall off. Causes engine run/start failure. Need to pull the starter to check. (On a hoist or something so you can turn the wheels with the engine in gear).
See post link below for pin photo.
Car and Mods:
