Oil Filter - Drain-Back Check Valve
Old 05-05-2006, 04:37 PM
EricAl's Avatar
Default Oil Filter - Drain-Back Check Valve
The MAHLE oil filters I had been using apparently have a drain back check valve in the filter body. At least I think that is what I see, but the MANN filters don't seem to have this feature.
I had though BOTH were anti drain back filters. Are they? Or do I not understand what I am seeing.
Old 05-05-2006, 05:26 PM
repeater's Avatar
Default It really doesn't matter....
The filter on the AAN sits in such a way that oil cannot drain back out of it. On other Audi applications, like my A6, it is necessary to have an anti-drain back valve to prevent oil from escaping back into the pan, due to the angle of the filter (approx 45 degree angle). Sure, having one is nice I guess for whatever reason we want to believe, but fact is it's pointless on our cars.
Old 05-05-2006, 05:49 PM
Bill the Cat's Avatar
2nd.. Put yur $$$ into the best damn filter you can get. I use Mann. (Mahle is a great 2nd)
Old 05-05-2006, 06:39 PM
tpierce's Avatar
Default as repeater stated, it isn't required, but is nice to have
It is for when the engine is shut down, it could end up sucking the oil filter dry in the last few seconds, or the filter could leech back into the pan, but since our filter are vertical, it isn't too important.
Old 05-05-2006, 10:39 PM
TabulaRasa's Avatar
Default Related question for you guys
When you do an oil change, do you fill up the filter with fresh oil before you spin it on? I do.
Old 05-06-2006, 06:14 AM
repeater's Avatar
Default Yes.
If you don't, the engine is oil starved for 3-4 seconds while the filter fills up.
Old 05-06-2006, 07:22 AM
repeater's Avatar
Default And if you have to use domestic.....
Baldwin or Purolator Pure One
Old 05-06-2006, 08:02 AM
And if the only filter available is orange - park your car.
Old 05-06-2006, 11:05 AM
repeater's Avatar
Default Yep, except the new tough gards are not a bad filter...
They've gone to a metal cap on the filter element and are running nitrile gaskets and drain backs in them. They are much, much higher quality that the cheap-o Frams.
computrtutr
08-26-2008 04:10 PM
egp320i
07-01-2003 01:31 AM
chexa4 T
11-19-2002 08:15 PM
SWiseman
04-20-2002 04:34 PM
leonardl
01-23-2001 12:09 PM
Quick Reply: Oil Filter - Drain-Back Check Valve
