| Audi Original "S" Cars Discussion forum for the Audi Audi Ur S4, Ur S6, S2 & RS2 |
#1 | ||
_____________________________________ 1991 VW GTI VR6 2007 Audi A3 3.2Q |
#2 |
![]() Join Date: Feb 2001
Naturally, IMHHEO(tm), Dave F. aka the Librarian Car and Mods: 93 S4, 1.8t coil pack conversion (First in world using integral POS coil packs (??)), CF (OE), S6 steering wheel, RS2'd, Samcos, MRC, TDS-1, Apikol FMIC, Eibach/Bilstein, BIRA Sys 1, relayed FP Click here to link to the UrS FAQ Thread Start Uncle Dave says "You want my 'high horse, elitist' opinion ?(IMHHEO(tm))Then just post something stupid." Unofficial Chief Cat-herder Vancouver UrS-car club |
#3 |
It's been ordered!
Anything else I should plan on doing in preparation of running the higher boost? Hoses, bypass valve etc? How much different will my car be with this program? Should I be blown away when I take it for it's first test drive?
#4 |
Tech Guru
![]() Join Date: Oct 2002
So will your hoses in a short time. Think about Samco hoses and an upgraded bypass valve.
4Driver4 "Never give up the throttle until the bitter end." -RC 2005 A6 Sedan Q 3.2 (wife's whip) 2000 A4 Avant Q 2.8 (daily driver) 2003 Mini Cooper S (Fun!) 1995 Mazda Miata: the anti-Audi 1999 Mazda Miata SSB: track beotch 2003 GMC Yukon Denali XL: the anti-earth 2004 Dodge Dakota: hey, at least it's stick and 4x4 |
#5 |
again, I think he (Sean) is pushing his luck (Right Sean?)
Dave F.
#6 |
Samco hoses are a good idea but possibly are overkill. The original hoses may hold up quite well. The operative word is "may".
Bob Myers
Bob M. |
#7 |
Yeah, I plan on replacing the boost hoses anyways. I've already replaced the bypass valve with the 710N.
#8 |
let go after chipping are original and would blow out with stock boost levels, chipping just accelerates this. The only one that goes is the cross over tube to intercooler (michelin man) because oil sits in the bottom and rots it out.
The metal x-over makes a big difference because you can clamp it with higher pressure.
1997 Audi S6 - Tornado Red on Ecru ---------------------------------- RS2 with MTM Chipset Porsche 928 GTS "big blacks" with 2 piece 993tt rotors S6+ euro sport springs and Boge shocks e-code xenons with range control motors The Rest ------------- 1990 Audi 90q 20V - The Back-up 1991 Alpina B10 BiTurbo - The Hobby Car 1992 VW Passat Wagon Syncro - The Wife's |
#9 |
I'm running MRC Stage 2, and the car appears to have all the original hoses. I just last week blew the turbo to x-over hose off of the x-over while making a pass (embarrassing). The following day, the SAMCO hoses arrived from the GP, so I've started replacing them. I noticed that the boost hoses were all in good shape, but the clamps were all fairly loose (probably due to permanent compression of the rubber).
At the very least, I would check all the clamps and make sure they're tight. I noticed that you can't tighten them too much before they slip a notch. The Breeze constant-torque clamps I got for my SAMCOs would probably work fine on the stock hoses as well. They're significantly wider and stronger.
![]() David Mackintosh Hood River, Oregon dcmackintosh@gmail.com 1995.5 UrS6 Avant. MRC Stage 2; T&M FMIC; BIRA Stage 1; H&R/Bilstein Sport; HSRSB; 17x8 OZ SL |
