What does this mean..."18010 P1602 Power Supply (B+) Terminal 30 - Low Voltage D"....
its for our A6, 1996 auto Q. Terminal 30 is that the fuses by the A pillar? I have no idea what any of it really means but we need to get an inspection sticker...stupid MA
Well, hard to guess at all of it, but
B+ refers to the output of the power supply, + rail. Most symetircal power supplies run "B+ and B-". Of course, since cars are single ended, thsi is kinda stupid.
Assume the first number is a code, referencable to the factory service manual. do you have it?
Assume the 2nd denotes WHICH power supply, and that the "power supply" is really a regulator somewhere.
The terminal is probably on that PCB.
All guesses.
Grant
All guesses.
Grant
yes it keeps coming back, goes away for a bit and comes back on...
i do and the P1602 is and Audi code i believe, its the only code preventing us from getting an inspection sticker and its annoying as all hell
im in the car now and it's under Mode 03: Emission realated fault codes....
Address 10(Engine): 1 Fault Found:
P1602 - Power Suppy Terminal 30: Voltage too Low
this is after converting it from Audi codes to VAG codes and this is the only code there is
I would start by throwing a dealer/Audi ignition switch at it, and see what happens.
But you don't say if this is an engine code, air bag code, ABS code, transmission code, or what.
The Bentley sez:
"J220 - Motronic Engine Control Module (ECM) Supply Voltage"
Ewww....I e-mailed the test procedure from the manual to you FWIW. I think <b>austinado16</b> may be onto something with replacing the ignition switch though. Otherwise, try to locate fuse S103 (I don't know where it is at the moment).
CEL...i'll try that it has 167K, would a switch out of a 1994 UrS4 work?
its a parts car that i have here right now<ul><li><a href="https://forums.audiworld.com/a6100/msgs/91572.phtml">https://forums.audiworld.com/a6100/msgs/91572.phtml</a</li></ul>
