Go Back   AudiWorld Forums » Audi Models » Other Audi » Audi 100 / A6 (C4 Platform) Discussion
Old 02-06-2007, 07:37 PM   #1
AudiVTanon.
Default Help! car overheat
I was coming off the highway and was losing power. Lost heat also on the way home, it was like 0 degrees. temp gauge works occasionally and was at like 2 o'clock, not good. Coming down the off ramp car shut off, was able to coast to park n ride. Coolant cap had been shot off under the hood and coolant was everywhere. Went back today and tried filling the resevoir, 50/50 pentosin and water. didnt start and coolant was pouring out from under engine. im pretty sure this isnt looking good. just bought a coupe so not that bummed, but would be nice to know whats the deal. thanks for any help..
AudiVTanon. is offline   Reply With Quote
Old 02-06-2007, 07:46 PM   #2
AudiVTanon.
Default 1992 100s
fwd
Old 02-06-2007, 08:11 PM   #3
A6Gary
Default Obviously you have a ruptured hose, radiator, or something else broken in the coolant system.....
If it was very cold, then you might even have a leaking/failed freeze plug. Since it leaks when you add any liquid, it should be fairly easy to find the source of the leak.
A6Gary is offline   Reply With Quote
Old 02-06-2007, 08:41 PM   #4
AudiVTanon.
Default Re: Obviously you have a ruptured hose, radiator, or something else broken in the coolant system....
i tried to follow all the hoses, couldnt really see. where is the freeze plug located? could it pop out and thats where the coolant is running out of? how big of a job is that
Old 02-07-2007, 02:37 AM   #5
Quattromond
Member
Default If the coolent reserve cap was blown off, then the car had pressure to do so.
So then correct me if im wrong but if a rupsured hose or freeze plug was the fault then that would be where the pressure goes so how could it still blow off that cap.
I would suspect something like a bad waterpump that stoped circulateing the coolent, which led to it overheating and then because of that it blew something apart. Does this sound logical?
2002 BMW 325xi, 97 A6 quattro, and 98 Acura integra.
Quattromond is offline   Reply With Quote
Old 02-07-2007, 04:42 AM   #6
4Driver4
Tech Guru
4Driver4's Avatar
Default Engine is toast.
If a car overheats quickly and dies, like if a hose bursts, you are generally luck to have damage confined to the head gasket and head.
If the car overheats slowly like with a gradual leak, the bolk gets super hot too and the bearings take a beating.
Sounds like your situation is the latter.
4Driver4
Growing old is mandatory; growing up is optional.
1980 VW Scirocco (mid-life crisis car)
1983 Mazda RX-7 (revolutionary sports car)
2003 Mini Cooper S (just because)
1995 Mazda Miata, Superdupercharged(anti-Audi)
1999 Mazda Miata SSB (track beotch, no plate)
2003 GMC Yukon Denali XL (the anti-earth)
2004 Dodge Dakota (hey, at least it's stick and 4x4)
4Driver4 is online now   Reply With Quote
Old 02-07-2007, 05:03 AM   #7
AudiVTanon.
Default Re: If the coolent reserve cap was blown off, then the car had pressure to do so.
could the cap have melted off? there was partial melting around where the cap screws on, and it wasnt lost it was sitting right there on top of the resevoir. im getting it towed today, so we'll see
Old 02-07-2007, 02:49 PM   #8
AudiVTanon.
Default yeup. donefor
was told that its seized and the engine is finished. anyone looking for some parts? it has navy cloth seats which are hard to find. anything else anyone is looking for let me know. dont have much long with it, couple days but i can do my best.
Old 02-07-2007, 04:15 PM   #9
islingtonaudi
Default 5-speed or auto?
islingtonaudi is offline   Reply With Quote
Old 02-07-2007, 04:38 PM   #10
VOoDOoGTX
Default will the 100 hood fit on the A6?
1987 Porsche 944 turbo
1996 A6 Quattro - Still going
AIM-VOoDOoGTX
VOoDOoGTX is offline   Reply With Quote
