Go Back   AudiWorld Forums » Audi Models » Other Audi » Audi 100 / A6 (C4 Platform) Discussion
Old 04-08-2005, 06:04 PM   #1
duece
Default 96 Audi A6 with several codes. Help?
I have a 96 A6 that I'm trying to save. A non-Audi shop says I have massive engine problems and junk the care. The following codes come up:
(anybody near chicago or west suburbs that can look at?)
P0116 Coolant Temp Sensor Out of Range
P1101 Unknown
P1106 unknown
P0401 insufficient EGR Flow detected
P0170 Fuel trim malfunction bank #1
P0173 Fuel trim malfunction bank #2
P0171 System too lean bank #1
P0174 System too lean bank #2
P1250 Undocumented Code
P0301 Misfire Cylinder #1 Detected
P0302 Misfire Cylinder #2 Detected
P0303 Misfire Cylinder #3 Detected
duece is offline   Reply With Quote
Old 04-08-2005, 06:48 PM   #2
beep-beep
beep-beep's Avatar
Default "Fuel trim" comes on mine evry three month. I just clear it.
But technically I should replace (or clean) the MAF sensor.
"System too lean" is not good. You can easely overheat the engine. Try to replace fuel filter (if it is old) and clean codes. If it comes again - then check injectors, pump, lines.
"Misfire" - replace spark plugs if old and check spark plug wires,
Dude, it sounds, that you did not tune up your engine for long time.
2006 A6 Avant
1996 A6 Avant 194K miles - RIP
beep-beep is offline   Reply With Quote
Old 04-08-2005, 11:22 PM   #3
A6Gary
Default "System too lean" & "Misfires" are signs of a bad MAF sensor....
P1101 = O2 Sensor Circ., Bank 1, Sensor 1 Voltage too Low/Air Leak
P1106 = O2 Sensor Circ., Bank 2, Sensor 1 Voltage too Low/Air Leak
P1250 = Fuel Level Too Low
A6Gary is offline   Reply With Quote
2, 2001, 96, a6, audi, bank, code, fuel, location, malfunction, p0116, p0173, p1250, sensor, trim
