#1 | ||
Member
#2 |
The trim piece is some kind of rubber. I'll probably go hunting for some good "waterproof" two part epoxy some day.
#3 |
Junior Member
They are all clipped on, I'm pretty sure... mine has been fine on my '94 100CS... one piece on the A6 has come off, but it's because of a broken mounting clip. I have the new part, waiting to get it painted.
I would try to find the problem, if there is one. If it's a broken clip-on or something, replace it. I'm not completely sure if the trim and mounting pieces can be ordered separately or not. You would have to check.
Muhammad |
#4 |
Member
Its the trim from the rear driverside door.. It fell off a couple of times before - I'd just hate to see it fall off on the highway one of these days...
#5 |
Junior Member
My small trim (actually on the rear fender) is the piece that falls off. But only when it is brushed up against or something. Never on the road. The actual panels are the same on the '93 as on my '96, so the actual trim mounting method is going to be similar. There should be a white "mounting piece" that the trim clips onto. The white piece mounts directly to the panel or door with screws, probably. Check the snap points. One might be bent or broken off... IMO the entire white mounting piece will probably need to be replaced, or the trim piece of there is a snap point broken off that piece.
Muhammad |
#6 |
Junior Member
I had my rubber part start to fall off, and had it replaced for $25 at a local body shop.
In and out sorta thing.
#7 |
The trim pieces rusted in the middle and caused them to pull away from the clips.
As a short term solution I pulled out the metal inner piece and glued the rubber strip to the white mounting points on the door using 3M molding adhesive. So far so good! Sam. |
#8 |
the old fishboats. Nice dark wood, hard as nails, so heavy it sinks.
Maybe I could get my 0-60 time up time 12 seconds !
#9 |
How easy is it to replace a broken mounting clip? Can I do it myself or do I have to go to a body shop? The white clip that holds the molding to the door on the passenger side is broken. If you have instructions on how to do it - it would help a lot. Thanks.
