Go Back   AudiWorld Forums > Audi Models > Other Audi > Audi 90 / 80 / Coupe quattro / Cabriolet Discussion
Old 08-02-2007, 10:40 PM   #1
DDMan
Account #: 81834
Default How to remove ignition key cylinder?
So, since my ignition key cylinder broke, I have been trying to figure out how in the world I am to remove the ignition cylinder from the dashboard! If anyone can tell me how I would greatly appreciate it. I purchased a new cylinder, and keyset, and now I just have to put it in so I can get my radio back and dont have to start my car with a screwdriver.
Can anyone point me in the right direction? I searched, but all I can find is replacing the electrical part of the ignition switch, and not the key/tumblers/cylinder
DDMan is offline   Reply With Quote
Old 08-03-2007, 03:30 AM   #2
v6nside
Account #: 115874
Default Re: How to remove ignition key cylinder?
I just did this last weekend, really easy.
Remove the lower dash piece under the steering column. Remove the cover around the steering column (2 screws), you will see 2 screws holding the instrument cluster in place, remove and pull out cluster, disconnect wiring. You will now be able to see the top of the cylinder.
On the left and right you should see red paint covering 2 flat head type screws holding the cylinder in place, use a small screw driver to loosen the screw and the cylinder will slide out. Disconnect, replace, reverse the process. 10 mins max.
v6nside is offline   Reply With Quote
Old 08-03-2007, 04:00 AM   #3
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
Default That's for the electronic portion only.
4Driver4
Growing old is mandatory; growing up is optional.
1980 VW Scirocco (mid-life crisis car)
1983 Mazda RX-7 (revolutionary sports car)
2003 Mini Cooper S (just because)
1995 Mazda Miata, Superdupercharged(anti-Audi)
1999 Mazda Miata SSB (track beotch, no plate)
2003 GMC Yukon Denali XL (the anti-earth)
2004 Dodge Dakota (hey, at least it's stick and 4x4)
Old 08-03-2007, 04:03 AM   #4
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
Default Look at the new cylinder.
Does it have a little spring tab on the side to lock it in? (I have no idea what year and model you have). If it has the tab, you'll need to locate the spot on the aluminum housing in the car where that tab should be on the old switch. Drill a 1/8 hole in the aluminum and use a small screw driver to depress the tab. Pop the cylinder out.
4Driver4
Old 08-03-2007, 04:47 AM   #5
awdaudi
Junior Member
Account #: 8272
Default installed.
TheRingmeister // Greensboro NC
....why on Earth Audiworld? long live the world according to quattro
90cq // 91 90q 20v sport // 92 UrS4 //08 Q7
gone..
90v8 //99.5 A4 1.8T Avant //01 allroad
awdaudi is offline   Reply With Quote
Old 08-03-2007, 04:48 AM   #6
awdaudi
Junior Member
Account #: 8272
Default ....for about $9...here's how
gone..
Old 08-03-2007, 05:41 AM   #7
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
Default Um yeah. I really don't like those setups.
What does this have to do with the lock cylinder?
4Driver4
Old 08-03-2007, 06:57 AM   #8
chefbob
Account #: 84147
Default Tom is teh oem king
Whips in the stable
2002 Honda Rc51 1000cc v-twin
1993 Urs4
1995 90 quattro
1998 a4 1.8t
1986 4kcs
1999 F-deuce50 V-10
chefbob is offline   Reply With Quote
Old 08-03-2007, 07:12 AM   #9
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
Default An ignition switch is $30 and can be replaced several times in the time it...
...takes for that mod.
4Driver4
Old 08-03-2007, 07:44 AM   #10
chefbob
Account #: 84147
Default meh! to you and your old fashioned way of thinking :)
Whips in the stable
1993 Urs4
1995 90 quattro
1998 a4 1.8t
1986 4kcs
1999 F-deuce50 V-10
1990, 90, audi, cylinder, housing, ignition, key, keycylinder, lock, mazda, miata, removal, remove, removing, suburban, vw
Forum Jump
