Go Back   AudiWorld Forums > Audi Models > Other Audi > Audi 90 / 80 / Coupe quattro / Cabriolet Discussion
Old 02-24-2005, 06:29 PM   #1
cklanke
Account #: 53133
Default Automatic Transmission--- Nasty Grinding Noise in Park and Neutral
My '94 90-series with 115K seems to have developed a strange problem. While stopped this afternoon I shifted from reverse to drive and briefly heard a loud grinding noise. It drove fine... without noise until I placed it in Park. The loud grinding noise is there in Park or Neutral but not while in a driving gear. The car doesn't slip gears and it shifts thru it's gears fine. My tranny fluid is clean and the level is right where it should be.
Tonight while re-testing it I noticed that my headlights diddn't work (they would if I pulled on the bright adjustment lever, but wouldn't when on hi or low beam without the lever being held). Could these be related???
Anyone have any insights to these problems?
cklanke is offline   Reply With Quote
Old 02-25-2005, 03:58 AM   #3
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
Default Is it possible that the starter is engaged? Bad ignition switch?
4Driver4
Growing old is mandatory; growing up is optional.
1980 VW Scirocco (mid-life crisis car)
1983 Mazda RX-7 (revolutionary sports car)
2003 Mini Cooper S (just because)
1995 Mazda Miata, Superdupercharged(anti-Audi)
1999 Mazda Miata SSB (track beotch, no plate)
2003 GMC Yukon Denali XL (the anti-earth)
2004 Dodge Dakota (hey, at least it's stick and 4x4)
Old 02-25-2005, 04:41 AM   #4
juzzo
Account #: 88318
Default pain, hoped for somethin ....
different as a solution,you may look my post elsewhere)
juzzo
juzzo is offline   Reply With Quote
Old 02-25-2005, 09:40 AM   #5
cklanke
Account #: 53133
Default Re: Is it possible that the starter is engaged? Bad ignition switch?
Nope. Not a starter grind. My car had been running for a while before the noise occured. Probably not the starter.
I can't figure out why the ignition would cause a grind... but since the headlights were affected too I had thought in that direction too.
I found an A4 post a couple of weeks ago describing the same problem (neutral and park loud grind and lack of headlights). The guy hasn't responded yet though.
Old 02-25-2005, 09:44 AM   #6
cklanke
Account #: 53133
Default Re: Here's the best solution-
No... wife in med school and twin toddlers. I have done an auto to 5-speed swap before (Saab 900T) but I have neither the interest or time anymore.
Why would these problems be linked? An electrical snafu that could affect both? Could a bad torque converter cause the grind?
Still searching...
a4, audi, automatic, car, chevy, grinding, grinds, loud, neutral, noise, nuetral, park, put, transmission, transmisson
Forum Jump
