Diff fluid....redline or amsoil. Opinions?
Old 09-30-2002, 04:00 AM
Playerseightball's Avatar
Old 09-30-2002, 06:34 AM
AudiWorld Expert
MikTip's Avatar
For what car? Year? Manual or Automatic? Front or rear diff?
Old 09-30-2002, 08:09 AM
No Bozos!
squidix9's Avatar
Default For a manual trans
There have been quite a number of threads on this topic. Do a search, and you'll find many opinions.
I use NEO 75-90 in the rear diif, and RHD in the tranny. I want the best wear resistance I can get. Plus, I have limited slip, so wear is a big concern.
Redline and Amsoil are also good products too.
Old 09-30-2002, 12:35 PM
ARK
ARK's Avatar
Redline products ARE NOT API tested / certified!
Old 09-30-2002, 03:45 PM
AudiWorld Expert
MikTip's Avatar
Default Re: Redline products ARE NOT API tested / certified, and............?
How does this effect us?
Old 09-30-2002, 06:39 PM
Default Re: For what car? Year? Manual or Automatic? Front or rear diff?
Unfortunately Auto(slush box), but will be replaced with 5speed trans when it goes. 97(manufactured 9/96) A6q 2.8l sedan ENG:AFC. I think the correct type diff fluid is 75w90 but will have to check...unless someone else knows for sure. Trans Dex II/III? Has anyone had experience with amsoil diff/trans fluid? Or hyas anyone tried both with noticeable results between two? Thought? Opinins? I will have tranny fluid flushed again (last time was 10k ago) current miles on vehicle=71k. Just because of the recent incident relating t thermostat problems which probably heated the trans fluid (the oil temp was a bit high at the time of incident) and now it may have lost its viscosity/chemical structure.
Brad
Playerseightball@aol.com
Old 09-30-2002, 07:06 PM
No Bozos!
squidix9's Avatar
And this means what?
Old 10-02-2002, 10:36 AM
ARK
ARK's Avatar
Default This means that Redlines claims as to meeting the minimum lubrication / performance requirements....
have not been verified by an independent testing lab. These oils may not meet industry minimum requirements. Why Redline does not submit their products for independent testing is beyound me. EVERY other lub manufacturer does!
Old 10-03-2002, 11:45 AM
No Bozos!
squidix9's Avatar
Default A few reasons I suppose
1. It costs a lot of money to submit for certification. AND, you must produce your product, and continually test production to meet spec. I suspect they are currently doing ASTM D2887, and shear testing, but not performing API spec testing. Just a guess, not based on any factual nformation.
2. It isn't sold for street use, no need
3. It IS sold based on word of mouth and reputation
Nogaro Stg3
15
05-26-2013 10:22 AM
Jon_Rhea
11
10-08-2008 06:20 AM
audiman4
Audi Original "S" Cars
02-15-2006 10:49 AM
ZephyrS4
06-24-2004 02:06 PM
A44flyin'
02-06-2004 08:57 AM
Quick Reply: Diff fluid....redline or amsoil. Opinions?
