Go Back   AudiWorld Forums » Audi Models » Audi allroad
Old 05-09-2006, 10:53 AM   #1
SKIroad'r
Default Shop Compressor, Tools -- looking for a recommendation
I'm looking to pickup a shop compressor and tool set in the near future and I'm looking for recommendations. I am occasional DIY'er so I don't need a top of the line professional set, but something durable and of good quality. Not sure what "features" I would need either, but ideally something that would allow me to set torque. Any other thoughts or specific recommendations?
2002 allroad 2.7T Tip
AutoSpeed Stage I Flash, 710n DV's
H-SPORTS (Hard)
Magnaflow mufflers with 3.5" tips
K&N Filter (in stock box)
35% Side Tint, 5% Rear Tint
Summer shoes (on now): Yokohama Avid W4S on RS6 Reps
Winter shoes(in storage): Hankook Icebears 17"
Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners
SKIroad'r is offline   Reply With Quote
Old 05-09-2006, 11:08 AM   #2
paulroad
Default sears/craftsman.
4/23/11: S4 Premium Plus, S'Tronic, Nav, Titanium body
Original Ride:
• Bought New May 2003 allroad 2.7t 6 Speed
• Sold @ 217,856 miles on April 23, 2011
-Mod/Repair Log
2400 Miles 5/28/11
New Conti Extreme DWS A/S Tires--smooths out the ride
OEM Dipstick--Need to see and smell the oil
OEM Rubber Mats--Look better than Stock Carpet and last longer
paulroad is offline   Reply With Quote
Old 05-09-2006, 11:19 AM   #3
BlueDog
Default second
you don't need the full 6 foot standing tank version, but something of a decent size. You won't ever regret getting a larger compressor, but if you get one of the small "handyman" sizes, you can quickly outgrow it.
I have one like this at home. 33 gal. Plenty of capacity for various tools and tasks. I've used it for painting a car. This version I can also charge it up, then unplug and drag over to fill the tires on my tractor or trailer, etc. Can also throw it in the trailer to take to the track.
BlueDog is offline   Reply With Quote
Old 05-09-2006, 12:41 PM   #4
Ink Ming
Default Coleman
"Screws fall out all the time, the world's an imperfect place."
'08 S5
'07 FJ
'06 Sienna
Ink Ming is offline   Reply With Quote
Old 05-09-2006, 12:49 PM   #5
JAH1
Default I need one too but not sure about size or psi? Can anyone chime in...
... I am not going to build a house or anything but would like it to run a nail/brad gun now and again. (in addition to filling all the tires w/air). Anything wrong with those ~$100-150 ones at Lowes etc?
TIA,
Joe
JAH1 is offline   Reply With Quote
Old 05-09-2006, 12:54 PM   #6
Ink Ming
Default Nail gun and compressor
'08 S5
'07 FJ
'06 Sienna
Old 05-09-2006, 01:04 PM   #7
SKIroad'r
Default Ooh nail gun -- should help with the deer problem
H-SPORTS (Hard)
Old 05-09-2006, 03:18 PM   #8
Rowdy ar
Default it depends...(long)
For shop compressors, it helps if you can estimate the kinds of tools you hope to run. Air tools usually state the desired or maximum PSI (lbs of air pressure per square inch) and most compressors allow you to regulate this, but make sure the parameters for both static pressure and estimated volume match.
Home compressors need to be drained after each use, unless they are in continuous daily use, so that the water that condenses in the bottom doesn't rust out the tank, or make its way into your tools. Small compressors are cheap, portable and have a quick cycle time to build up pressure, and are fine for nail guns, etc., and other tools that require high pressure but low volume, and therefore don't really use much air. Some tools take a lot of air; an single orbital sander can keep a 5 hp compressor with a 40 gal tank busy. Older style paint guns require moderate pressure and dry, clean air. Some of the newer HVLP (high volume, low pressure) paint guns are much more efficient.
If you don't feel that you are getting good advice at the local Home Depot or Lowe's, try one of the online tool sellers; they often have a good knowlege base.
Rowdy ar is offline   Reply With Quote
Old 05-09-2006, 05:04 PM   #9
ArchAudi
Default Porter cable c3151 used in my shop and I can even spray with it.
Heaven is where...
The police are British
The cooks are Italian
The lovers are French
The mechanics are German
And it's all organized by the Swiss
Hell is where...
The cooks are British
The mechanics are French
The lovers are Swiss
The police are German
And it's all organized by the Italians
ArchAudi is offline   Reply With Quote
Old 05-09-2006, 05:07 PM   #10
BlueDog
Default You could make due with the smaller ones, but...
that's about all you'll run with it. If you want to run something like an air chisel or you pick up a bead blasting cabinet for refinishing metal work (auto parts or antique fixtures, etc) then you'll be out of range of the small ones. You could possibly make due, but it'll run constantly trying to keep a charge.
