Go Back   AudiWorld Forums » Audi Models » Audi allroad
Old 03-08-2006, 07:36 AM   #1
Scaryfast
Default Fog light mod
I finished the fog light mod. Thanks to K2audi for posting his experience on this modification.
This allows me to run my parking lights along with the fogs as daytime running lights for safety when driving two-lane roads. The mod does not change the high beam disable of the fog lights or the 'lights left on' warning chime.
I found that you only need one add-a-circuit fuse tap to complete this modification. Autozone had this part for $5.99. I cut off the original crimped butt connector and added a male blade connector. I did file the edges of the blade connector to make it narrower (like a fuse blade).
I used the #39 fuse circuit as my hot tap as did K2audi. I removed the 15 amp fuse from the #39 slot and the 15 amp fuse from the #36 fog light circuit. I placed those fuses in the add-a-circuit tap. So, in the tap, the first 15 amp fuse provides protection to the #39 hazard circuit, and the second 15 amp fuse delivers power and provides protection for the fog lights via the red supply wire. Basically the add-a-circuit replaces the #36 fuse holder. You just plug the bladed supply wire in the right side of the #36 holder. This is important. The left side is linked to the relay that provided power to the fogs only when the headlights were on. When the headlights are off, the relay is grounded at one end of the coil. As a result, if the supply is connected to the left side, it will blow the fuse.
First, I plugged the blade connector in the right side of the #36 fog light circuit. This way, it is not hot while I'm making the connection. Second, I plugged the add-a-circuit tap into #39. That's it; attempt at your own risk.
The switch physically functions the same way. However, with the switch in the parking light position, the fogs come on when the switch is pulled out (yes, front and rear).
Paul
'02 allroad 2.7T Tip
Scaryfast is offline   Reply With Quote
Old 03-08-2006, 10:27 AM   #2
K2audi
K2audi's Avatar
Default nice!...that makes it even cheaper.
2007 Q7 4.2, Garnet Red - The 1st customers to do Audi European Delivery 12/11/2006
20 in. wheels, Navigation, Panorama Sunroof, Cold Weather Package, Technology Package, A.M.I. Satellite Radio, Tow Package, Clear Rear Tail Lights, Tint Windows %35 Front
2006 S4 Avant, Sprint Blue, 6sp. Manual, (Summers)- OEM Titanium 5-arm Rotor Design Wheels w/ Conti DWS's, (Winters) - OEM BBS CH's w/ Pirelli P-Zero Nero's, Premium Pack., Audio Pack., Cold Weather Pack., RNSE, Rear Parktronic, Carbon Fiber Belt Trim, Euro Tails, 25% Tint, RS4 Pedals
"Gone but not Forgotten"
2002 allroad "Olympic Edition" Sprint Blue 2.7T w/ tip
2006 A4 Avant, S-Line w/ DTM front bumper
"Vorsprung durch Technik"
"Any car that merely takes you from A to B does not go far enough." - August Horch
K2audi is offline   Reply With Quote
Old 03-08-2006, 10:44 AM   #3
audiallroadin'
Default cool...thanks for the writeup.
1980 Audi 4000
1985 Audi 4000S
1999.5 Audi A4 2.8
2003 Audi allroad
H-Sports (Hard)
Tints- Front 4- 35% Rear 3-20%
EBC Ultimax BlackDash USR Slotted Rotors
EBC RedStuff Ceramic Pads
Sirius Satellite Radio- Starbase unit (hardwired)
audiallroadin' is offline   Reply With Quote
Old 03-08-2006, 12:25 PM   #4
2002ar
Member
Default Good show, but having the rear fogs come on is a MAJOR problem, IMHO.
2002ar is offline   Reply With Quote
Old 03-08-2006, 01:25 PM   #5
uber_ar
Default Re: Good show, but having the rear fogs come on is a MAJOR problem, IMHO.
You still need to pull the switch out to the second position for the rears to come on.
uber_ar is offline   Reply With Quote
Old 03-08-2006, 02:34 PM   #6
uber_ar
Default added to > allroadFAQ.COM
Old 03-09-2006, 12:40 PM   #7
pdxroad
Default Good write-up. What happens when...
...you turn off the ignition? Do the fog lights stay on or do they turn off leaving the park lights still on?
2004 Alpaka 2.7T, TIP, beige/light brown
cold, XM, premium
Hartmann F1's (18") and Michelin Sport A/S
OEM single-spoke and Dunlap M3's (winter)
H-sports on 'hard'
Tip Chip (GIAC)
WeatherTech Cargo Liner
Ultimate Cup Holders
Yakima Rack [Viper bike mounts]
Yakima Hitch mounted rack [Kingpin 2]
Packasport cargo box
Class II Hitch w/1-1/4" insert to custom 2" receiver
IceLink w/XM and in-dash CD Changer still working!
Euro [half convex] Drivers side mirror [heated, dimming]
35% tinting all around, even sunroof
DRL fog lights
pdxroad is offline   Reply With Quote
Old 03-09-2006, 01:17 PM   #8
Scaryfast
Default Re: Good write-up. What happens when...
Thank you.
When the ignition is off, the fog lights, if pulled on, remain on with the parking lights.
However, you could change this behavior. I chose the power supply from the #39 hazard circuit which has constant power. You could tap a different circuit that is only hot when the ignition is on, and then the fog lights would only be supplied with power and functional when the ignition is in that position.
Paul
15, 2002, a4, a6, allroad, amp, audi, blade, car, connector, fog, foglight, fuse, light, lights, mod, modification, tap, wire
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
