| Audi allroad Discussion forum for the original Audi allroad |
#1 | ||
2004 allroad 2.7T MT6 Atlas Gray Premium Pkg. Cold Pkg. Bose Sound H-Sport anti-sway bars (soft) DTS Mud flaps allroad winter mats and cargo liner Passport 8500 Winter setup: Hankook IceBears on stock single-spoke wheels Summer setup: 18" Hartmann replica B7 RS4 - 252 wheels with 245/45/18 General Exclaim UHP tires and 15mm H&R spacers |
#2 |
Symptoms were not like you describe, definitely no clunking. It started as a whine that got louder and louder. It sounded a lot like a tire that is badly cupped, kind of a low howl. I drove on them 5,000 miles before I finally realized it was the bearings and not the old tires.
#3 |
took me a while to figure out they were bad
#4 |
Two good friends who have recently done significant rebuilds on C4 S6s discovered the had bad front wheel bearings, that were not making the typical bad bearing noise. Once they got everything apart, the bearing had significant vertical play. Maybe Audi bearings are somehow different than typical...it's definitely worth checking into.
You can actually test them yourself. Jack up that corner of the car, and grip the wheel tightly with one hand on each side of the tire. Using some pretty decent muscle, try to move the tire front-to-back (parallel to the side of the car) and up and down. If it has a small amount of play, your bearing is shot. It'll feel loose for a small distance then abruptly stop, this won't be a progressive feel as if you were compressing the suspension. Otherwise, check your strut mounts, and then start checking your steering rack and centerlink. Best of luck! |
#5 |
yes, Left rear Wheel Bearing went out a 35k on 01 AR. Low freq whinning noise on broad med speed right turns on hwy. Audi Palm Springs did the $650 replacement. Faulty seal on bearing, but 1 month out of warrentee... yikes
3rd set of front rotors also. This is crazy! |
#6 |
2001 allroad, 6sp, H-Sports, Arnott Gen-II |
#7 |
but rather some kind of bushing, because in addition to the clunking sound, it also makes kind of a rubbery sound, like rubber being squeezed against metal, or rubber against rubber. I might have to go to a reputable local shop and pay to have the problem diagnosed, then go back to the dealer and point it our to them... Thanks again for all your input, it is appreciated!
