Go Back   AudiWorld Forums » Audi Models » Audi allroad
Old 11-28-2005, 02:14 PM   #1
ar2002
Junior Member
Default Falkens, 225/55/17 are worn out afte 17k miles; do they need more than 38 psi?
Put the snows on Saturday and noticed the Falkien Ziex 512s, OEM 225/55/17 size, were at the wear bars at teh inner & outer edges of all 4 tires. There was plenty of tread in the center of the tire. I ususlly run 40F/38R. Does one need to run 45 psi in these tires for even wear? The max pressure listed on 'em is 51 psi. The tires have 17,000 miles on them; about the same as my OEM Pirellis when I replaced them. Interestingly, my snow tires, 16" Arctic Alpins, are wearing evenly with about the same 40F/38R air pressure and have lots of tread left after three seasons (17,000 mi) and will last this winter easily.
2002, Alpaka/Beige, TIP.
Preferred, Premium, Convenience.
Heated Seats, Ski Sack, Hitch.
ar2002 is offline   Reply With Quote
Old 11-28-2005, 02:22 PM   #2
paulroad
Default Well... yes....
I got 30K from my first set.. and now on the second..
4/23/11: S4 Premium Plus, S'Tronic, Nav, Titanium body
Original Ride:
• Bought New May 2003 allroad 2.7t 6 Speed
• Sold @ 217,856 miles on April 23, 2011
-Mod/Repair Log
2400 Miles 5/28/11
New Conti Extreme DWS A/S Tires--smooths out the ride
OEM Dipstick--Need to see and smell the oil
OEM Rubber Mats--Look better than Stock Carpet and last longer
paulroad is offline   Reply With Quote
Old 11-28-2005, 03:34 PM   #3
ar2002
Junior Member
Default Door frame said 36 psi, or less depending on load. Seems few people over 40 psi in OEM size.
Old 11-28-2005, 05:48 PM   #4
mustbeaudi
Default So, Paulroad, pray tell - I have 512 and set at 36 for wife's comfort - what need it be & why?
mustbeaudi's rings: 07 Lava A3 2.0t DSG Prem OpenSky Tech Audio
SOLD - 01 allroad (hers) - to a new member of the Audi fold.
SOLD - 02 S6 (his) - now with a fellow AW'er in CO.
mustbeaudi AT yahoo DOT
mustbeaudi is offline   Reply With Quote
Old 11-28-2005, 05:58 PM   #5
paulroad
Default IIRC the frame label is written for OEM rubber....
Original Ride:
-Mod/Repair Log
2400 Miles 5/28/11
Old 11-28-2005, 06:10 PM   #6
LCP
AudiWorld Expert
Default Plenty of tread left in the middle with both outer edges gone means your tires are overinflated...
...so you overinflating them to 38psi likely caused them to wear out early. Look at what the tire pressure insert shows and stick closer to that for your normal load. FWIW, I run 34/34 on the 245/50-17's on our allroad, and I feel that's borderline too high based on what's on the sticker and the larger size tire I'm running.
<I>"I can't stop apexing"</I>
<a href="http://picasaweb.google.com/lh/photo/7E23ZNlHEBHxjEVE7tCbQA?feat=embedwebsite"><img src="http://lh6.ggpht.com/_3Hi-iQCt0Wk/SceZdRtx1fI/AAAAAAAABX8/vjV2gbtW7MI/s400/LCP-AWsig-collage.jpg" /></a>
<small><b>2000 S4</b> :: Nogaro Blue :: 6-spd :: AWE RSK04 :: AP Racing 13" 4-pots
H&amp;R Street Coilovers + 19mm rear sway bar :: APR Bipipe
RS4 ICs :: Autospeed DPs :: Borla :: Aquamist 1s
UUC 40% short shifter w/spacer mod :: AWE center vent boost guage
Lightweight flywheel :: 18x8 Ronal LZ's :: 235/40-18 Pilot Supersports
<b>NEW:</b> 2011 Acura MDX :: Polished Metal Metallic
<b>GONE:</b> 2002 allroad :: Atlas Grey :: Tip :: 235/55-17 Yokohama Avid ENVigor's</small>
LCP is offline   Reply With Quote
Old 11-29-2005, 06:24 AM   #7
mustbeaudi
Default His wear was edge, not center, as you interpret. Opposite.
Old 11-29-2005, 07:27 AM   #8
paulroad
Default LCP... Sorry to differ.. but..
Overinflation causes the tread to wear in the center. Underinflation is the outer edges.
Original Ride:
-Mod/Repair Log
2400 Miles 5/28/11
Old 11-29-2005, 08:03 AM   #9
LCP
AudiWorld Expert
Default D'oh! Don't know how I confused those. Regardless, at 38psi, I don't think it's "underinflation"...
...that's causing the problem. Seriously, it could be a combination of hard cornering wearing out the outer edges and a misalignment wearing out the inner edges.
