| Audi allroad Discussion forum for the original Audi allroad |
#1 | ||
#2 |
2010 Audi A6My Garage Join Date: Aug 2004
Keep your filter box clean and replace your filter at least but maybe not more than 30K mi
#3 |
![]() Join Date: Oct 2003
A turbo timer would be overkill (imho) You doing just fine with the care you give the car. AWB doesn't inpect the cars prior to or after a policy is issued.
If you are close to Concord NH, the best of the best tuners is right there. TJM Motorsport 235 Rear South Main Street Unit 223 Concord, NH 03301 1-866-dahlback (1-866-324-5222) Fax: 603-229-0055 Email: Info@tjmmotorsport.com Talk to Randy.. he is a former allroad owner and now just what to do.
![]() 4/23/11: S4 Premium Plus, S'Tronic, Nav, Titanium body Original Ride: • Bought New May 2003 allroad 2.7t 6 Speed • Sold @ 217,856 miles on April 23, 2011 -Mod/Repair Log 2400 Miles 5/28/11 New Conti Extreme DWS A/S Tires--smooths out the ride OEM Dipstick--Need to see and smell the oil OEM Rubber Mats--Look better than Stock Carpet and last longer |
#4 |
I am planning on installing these items on Saturday.
Two mods that go great together (2.7t) User account number (aid): 14326 Posted by Michael Benno on 2004-07-19 13:30:30 RS6 vented wheel Liner (or DIY venting) plus lower temp sender for coolant after-run system. I had done two mods recently each is justifiable in it's own right, mostly because they are relatively inexpensive and seem to have pretty decent face value justification. The first was adding vents to wheel liner to improve airflow through the intercoolers. S4's have them, RS4's have them, RS6's have a whole bunch of them. Sadly A6's and Allroad's don't we just get a bunch of heat soak on our already peuny IC's. I used the wheel liners from an RS6 (had to trim some bits). Did I notice a difference? I did not do any before/after IC temp tests and the butt dyno didn't notice. However, the theory is sound. Plus the liners were about $30ea from the dealer. The other mod I did was get a lower temp rating switch (~$30) that activates the after-run coolant pump. You can read about it out on the S4 forum. We all know that all turbos suffer from too much heat and hot shutdowns cause koching of the internal bits. The K03's seem to be more susceptible to heat problems. Furthermore most of us have never heard our stock after-run system engage. I used a 19-degree reduction in temp rating and now it comes on regularly after drives in the summer. The sysem activates the radiator fan on the lowest setting and pulls coolant through the turbos (and the rest of the system). Cool Huh? Well yes and no, the fan is pulling outside air into the engine bay and it really has not where to go. Hot air from the back side of the radiator literally soaks the engine bay with very hot air. Enter the wheel-well vents. Volia! Easy exits for heat. Now I can actually feel a lot of hot air being pushed out of the front wheel wells when the after run system is engaged. Makes me feel a lot better about reducing heat soak in the engine bay. Furthermore the RS6 wheel liners have vents that go all the way to the top well outside of the area of the IC's. At first I thought that this was dumb, why do I need to keep my windshield washer fluid cool? But heat rises, and when that after-run system kicks in you can really feel the hot air blowing out the top of the vents. Mike Benno A6 2.7t Michael Benno 2000 A6-2.7t (MTM1, Hsports, DIYSS)
Roose 2001 2.7T, 6SP, Blk Nav, Park, Premium, Twin Spokes V1 Hardwire, Short Antenna, Sirius Radio 35% Tint, Thule Racks/Box, Toy Guy SS, 605 pulled, Dunlop SP 5000 245/50/17 allroad OEM rubber mats, iceLink iPOD 402 Mod -10 F -5 R, window control with Key RS6 vented wheel liners(summer), after run lower temp. sensor, H-Sports Hard, Milltek Cat-Back, Dahlback DP's, Dahlback Racing DV's, RS4 Intercoolers, Dahlback Racing Stage 3, AWE DTS, SAMCO kit Blk, ECS tie rods, South Bend Clutch, Zimmerman 321x30 CD Rotors, mintex pads 112,~~~ miles "New s--t has come to light, man." The Dude |
#5 |
#6 |
I live just outside of Boston, but I work in Lowell, and spend a decent amount of time driving past Concord on my way to the Whites. If Randy is good, and knows ARs to boot, I don't mind driving north for mods.
The lower temp after run switch and the vents mentioned in roose1310's post sound like a perfect alternative to a turbo timer. Thanks for the info. |
#7 |
THey also run cars in the Euro Tuner Challenge.. you are in good hands..
Oh.. they are the US importer of Dahback chips and parts..so if you want to really do the car justice..
#8 |
are about all you need (except maybe some luck!) Other than that is is just a crap shoot. There were some manufacturing issues with the turbos so yours are either going to crap the bed early or not somewhat independant of how 'gentle' you are. (assuming some base level of responsibility)
There are more of us pushing or over 100K miles wiht stock turbos on chips than there are turbo replacements. I warm my car up properly and change the oil every 5K miles and do all other proper maintenance but once I'm warmed up I run the hell out of it on a daily basis.
Full RS6 bastardized allroad quattro alive and on the road. |
| Tags |
| 27t, allroad, audi, cool, period |
