Go Back   AudiWorld Forums » Regional & ACNA Discussion » Chicago Discussion
Old 02-14-2008, 02:35 PM   #1
mloiterman
Default < 16 F and A6 Brake and Tire Warnings
My wife's A6 Avant goes crazy every time it goes below about 16F.
Both the tire pressure warning and the rear brake warning light go off and never shut up until the ambient temperature goes above 17 or so.
Is it worth bringing in (semi-common problem), or are they just going to start swaping parts?
mloiterman is offline   Reply With Quote
Old 02-14-2008, 05:34 PM   #2
ZCD2.7T
ZCD2.7T's Avatar
Default I'm guessing that the car is an '05 or newer? If so, wrong forum. Try C6 forum:
Not that we don't want to help, but I'm actually not aware of anyone active on this forum that drives a C6 A6....
Sad, huh?
ZCD2.7T is offline   Reply With Quote
Old 02-15-2008, 07:09 AM   #3
spartanS4
Junior Member
Default Have you checked your tire pressures? When it gets really cold...
Your pressure drops in your tires and can set off the low pressure alarm. It's happened in my trailblazer before and they were down a few psi from what it should be. Took it being 2 degrees outside though.
No clue on the brake pad sensor issue. If you can see that there is plenty of life left I would just ignore it.
Sorry if you already knew this, I thought I would give you my experience!
Current: 993tt - No mods at all
Past: b5 S4 with everything (seriously)
SpartanS4 - Founding member of the Straight Line Whores (SLW's)
"Smooth, safe and remember, this **** is $$$, so enjoy yourself!"
spartanS4 is offline   Reply With Quote
Old 02-15-2008, 07:27 AM   #4
Nvr2Fst
Senior Member
Default tire psi will drop 1 psi for every 10 deg drop in temp. Im guessing the brake issue is temp
related also, but doesnt hurt to call the dealer just to be safe
Current.... 2008 GTI 4DR DSG, H&amp;R/APR
Former..... 2006 GTI DSG, EVOM/APR SLUT
Formerer... 2002 S4 TIP, APR/GIAC/MILTK
Searching. MKIII GTI VR6 project car
Proud Diehard Fan of the 2005 World Champion Chicago WHITE SOX!!!
Proud Papa....Please welcome Ashley Makenzie 5-9-07... 5-9-08, how time flys, 1 year old!!!!
Nvr2Fst is offline   Reply With Quote
2008, a6, warnings
