Old 11-06-2008, 02:54 PM   #1
stmcknig
Default 2004 B6/S4 Bose & CD Trunk Navigation upgraded to RNS-E
So I upgraded the head unit from Symphony II to the RNS-E with the harness that came with the unit. I didn't run an extension cable from the GPS antenna in the shark but used a small antenna behind the instrument cluster as all the guides recommend. So far everything seems okay - the RNS-E outputs to the DIS but I was told I should disconnect the 'original' CD Nav to avoid bus conflict - do I need to do that and what's involved....just remove the CD Nav unit from the trunk and disconnect all/some of the plugs?
I coded the RNS-E with a '9' to indicate Bose but cannot get 255 in channel 8 of the Adaptation - when I hit TEST it comes back with ERROR. Anybody an idea?
Anybody been down this path?
stmcknig is offline   Reply With Quote
audi, b6, bose, navigation, s4, symphony
HTML code is Off
