Old 03-23-2007, 11:06 AM   #1
SNOWnH2O
Default xm wire run to center consol?
I STFA and didn't find anything on this.
I am using my XM Inno with fm transmiter mounted in the center consol cup holder (works very well!). How should I run the wire from the back deck to the center consol?
Getting it out of the trunk is easy, obviouslly, but I'd like to just take it from under the rear seats, under the carpet, into the center consol.
Under the carpet seems to be the hard part. Any ideas?
SNOWnH2O is offline   Reply With Quote
Old 04-06-2007, 04:39 PM   #2
LI-S4
Default If I understand your question correctly, it isn't an easy job, but it can be done- ->
If you are saying you want to run a wire from the ashtray to the back of the HU??
There are multiple bulkheads that you need to get through before you can exit/enter the ashtray...I have a bunch of pics and a write-up if that is what you are asking..
If you mean how you can get down to under the armrest, etc. On the B5 there are two bolts uner the rear ashtray, one on each side of the console just in front of the shift surround and then the e-brake handle must be removed.. Then you can lift the center console out...
Clarify what you are hoping to do and I might be able to give your more detail...
"My wheel bolts require more torque than your Honda makes..."
Everything I write is my opinion. You are free to adopt it or discard it. If I say it, it's because I believe it to be 100% true...That is all.
...THE FIRST MOD SHOULD BE DRIVING SCHOOL - O.W.K.
LI-S4 is offline   Reply With Quote
HTML code is Off
