Old 09-02-2006, 01:59 PM   #1
A6turbo530
Default Does anyone know where i can get a passenger BOSE door speaker?
this is for a 2000 C5 A6 with BOSE system... and its the front pass door
mine makes a horrible buzzing noise when ever it hit a low tone (bass). its only bass, it sounds perfect with all other tones but if i pull off the door panel to inspect it, i'll just replace it assuming there not obsurdly overpriced... but this is Audi so hit me with the wost.
if anyone has upgraded their stock BOSE system and has a passenger side lower door speaker laying around id be interested as long as it was working when removed. TIA
2000 A6 2.7T 6-speed
APR 93 Octane Chip
ASP Stage 4 Feramic clutch w/ RS4 Pressure Plate
Fidanza Lightweight Aluminum Flywheel
ASP Street Density Trans Mounts
Hella Smoked Tail Lights
Blitz Digital Boost Gauge/Turbo Timer
Piggie Pipes
Custom Magnaflow 2.5” True-dual Exhaust
Short Shifter
Eibach Springs- 1.5” drop
PSK Rear Sway Bar
Pirelli P-Zero Nero Tires
A6turbo530 is offline   Reply With Quote
Old 09-02-2006, 03:32 PM   #2
avincar
Junior Member
Default I have two out of 2001 ar... but they look like crap, and yours do too.
2001 2.7T Tip ar
402 mod
Fog DRL mod
Sym II retrofit
BT retrofit
Ice>Link iPod interface
Morel components
Zapco amplification
DLS sub - all stealth
avincar.com
avincar is offline   Reply With Quote
Old 09-04-2006, 05:12 PM   #3
AudiFX
Default Ken, The Sport Seats Have Been Relisted On Ebay....
2000 A6 4.2/ AWE Tuning/GIAC ECU & TipTronic Chips, LLTek Cold Air Induction, MagnaFlow Hi Performance Cats, H-Sport Sways, Bilstein PSS9 Coilover Suspension, ECS Tuning Drilled/Slotted Rotors, Akebono Euro Ceramic Pads, DOT 4 Brake Fluid, ZeckHausen Racing TUV & DOT Approved Steel-Braided Brake Lines, Aluminum Pedals, Polished Mirror Housings, RS6 Rear Spoiler, Hella Clear Tail Lights, 18" x 8.5", ET30 Lorinser LM5 2 Piece wheels, Yokohama AVS ES 100 255/35/18's.
AudiFX is offline   Reply With Quote
HTML code is Off
