#1 | ||
1998.5 A4 2.8 Avant - TIP Chip - ECU Chip - S4 Suspension : RIP 2008 A6 3.2 Avant |
#2 |
in the tweeter line to filter out mid/lo frequencies. I've never seen a proper Xover in a stock system Bose or non Bose.
I would by pass all the Audi wiring, as it is shockingly bad. The pre-outs don't have the necessary screen to protect them from interference and even if you work out the pin-outs I guarantee you will have noise/interference problems with an aftermarket amp. Definately use the RCA adapter, don't use a speaker level input. The Bose amp speaker output is designed for a 2 ohm load, your speaker level input is a 4 ohm load so you will only get half the signal strength using this method. Also the Bose output is tweaked to match the wierd speaker setup. You will need to get a dealer to reset the HU back to non Bose mode as well (or someone with VAGCOM). |
#3 |
I bypass all the wiring in the system I have to have the VAG-COME thing done? Will they do that willingly?
THANKS SO MUCH for replying to this!! You've been a great help.
#4 |
| Tags |
| 2003, a4, audi, avant, b5, bose, layout, settings, speaker, speakers, subwoofer, system, tweeter, wiring, woofer |
