Old 04-13-2004, 05:59 PM   #1
boxx
Default I'm putting in a bypass with a switch for the CD changer
based on Jeff Bipes' design. It is for playing tunes from an ipod or GPS (pocketpc.) Bypass so that there is no wire cutting.
I ordered 13 pin connectors (male and female)from Buxcomm.com, switch and Relay from the local radioshack and I also looked at the link below for the wiring.
http://forums.audiworld.com/audio/msgs/1166.phtml
I'm trying to keep is as clean as possible.
How hard is it to remove the CD changer in the TT coupe? If any has done this, a little insight would be helpful.....
Thanks.
boxx is offline   Reply With Quote
Old 04-13-2004, 08:23 PM   #2
HACK THS
Default TT changer... PITA kinda...
You will need to remove the seat cushion for the rear reat- pull up hard until the front pops, then pull it forward and up, and it will slide out. Then remmove the driver side rear seat back- 2 bolts if I remember where the seat cushion came out, one of them also holds down the seatbelt connector. Then you need to use a deep socket to remove the nut holding the rear seat back pin- where the seat connects to the wall and clicks in. You need to loosen the nut and then unscrew the pin. Once the rear seat back and cushion are out then start pulling the panel away from the wall. It is held in by clips of sorts. You just need to pull hard. Slowly move your hand all the way around and keep pulling until the whole side comes free. It will be held still in place by the seatbelt-which runs behind it and then though the top as you will see. Once that side is out, twist it out of the way. You will now have full access to the CD changer and its mounting brackets. I would suggest you unmount it, tap your cables and away you go.
If you want to get real fancy you can then start to take the lower channel apart, and finally the lower dash and dead pedal. That way you can run your lines all the way up to the front and hit them OEM style ;-). That is more difficult, and the channel cover can easily crack- I cracked mine while running my power lines for my cars stereo.
Hope that helps... I can take some pics for you since my rear seats are out now... it is a mess so it might not be any huge help.
I approved this posting,
Tom
"Lifes too short to drink cheap" -Myself
"I am not normal... I am what normal should be"
Coming Soon Modifications:
SouthBend Clutch, Larger Manifold (Undecided), Larger Turbo(Undecided)
HACK THS is offline   Reply With Quote
Old 04-14-2004, 02:19 AM   #3
boxx
Default wow, sounds like a PITA.
is there a way to get access to the 13 pin cable end without fully removeing the panel?
can you could take a pic where the wire enters the changer? at least I'll know what i'm up against.
Thanks.
Old 04-14-2004, 07:35 AM   #4
JustJeff
Default Yes, it can be done by simply lifting up the panel from the bottom.
JustJeff is offline   Reply With Quote
HTML code is Off
