Old 12-05-2003, 05:21 PM   #1
Randy
Default Help! Blaupunkt adapter for Concert no longer available at Crutchfield. Any other sources?
Randy is offline   Reply With Quote
Old 12-05-2003, 06:15 PM   #2
JustJeff
Default Well, duh, my total mistake here, wire directly to the connector...
Look at these points on the harness, wire RCA jacks to these points.
i did this myself, works great.
JustJeff is offline   Reply With Quote
Old 12-06-2003, 04:34 AM   #3
Randy
Default Won't work. I need to access the preamp line outs. Thanks anyway.
Old 12-06-2003, 05:48 PM   #4
Steveo369
Default Huh? Jeff oughta know. He makes CD changer connectors on the side...
The diagram he's posting is the HU diagram. The pins designated "To Power Amp" are the preamp line outs.
Audi uses a common ground system for the line-outs. Just buy a set of RCA cables (female ends) or the various required parts of the cable, and hack them apart. Wire the center pin wire of each cable to the positive wires attached to the pins, and wire all 4 shield/grounds together and attach them to the ground pin wire.
Or, if you didn't quite understand this, and need the pre-wired snap in version, you can get it here:
AIM: Steveo369WA
Steveo369 is offline   Reply With Quote
Old 12-06-2003, 09:26 PM   #5
John P. (TT 225)
John P. (TT 225)'s Avatar
Default That's what he's telling you to do.
John P. (TT 225)
2011 S5 Coupe Quartz/Magma/Sport Diff/Carbon/B&O/6-Speed Manual
• A.W.E. Tuning Exhaust
• H&R Street Coilovers
• Vossen CV3 20"x10.5" x 4 (first in the U.S. on all four corners)
• Dipstick mod
• Clear bra
-2001 Audi TT quattro (Deposit placed in 1998; Car sold in 2008)
2001 Audi TT quattro (225hp) (Deposit placed in 1998; Car sold in 2008)
John P. (TT 225) is offline   Reply With Quote
Old 12-07-2003, 07:45 AM   #6
Randy
Default Anyway to attach to the RF and LF too? I have a 4 channel amp.
Old 12-07-2003, 08:04 AM   #7
JustJeff
Default Can you do some solder work? look here
I took apart the back of the radio to get at the circuit board for the rear connectors.
I soldered two molded RCA female jacks at these points. You don't really need to worry too much about doing this. Work carefully and take your time.
Old 12-07-2003, 08:46 AM   #8
Randy
Default Thanks for the help. I should be able to do that.
Old 12-07-2003, 08:27 PM   #9
Elf Power
Default check this websight. I need an adapter too.
http://www.continentalimports.com/acc_cable_out.html
Elf Power is offline   Reply With Quote
HTML code is Off
