Old 01-08-2003, 07:53 PM   #1
Ulilbastrd
Default annoying rattle with sub....
Did anyone ever experince an annoying rattle from the rear passanger side of the cabin when using a sub? I have a 12" mmat sub with a 300watt amp. if anyone ever had this problem is there a simple fix?
Thanks
2001 Audi A4 1.8TQ (2001-2006)
Casablanca White
2006 Audi A4 2.0Q (2006-2007)
Artic White
2012 Audi S4 (Present)
Ibis White
Ulilbastrd is offline   Reply With Quote
Old 01-09-2003, 03:50 AM   #2
Phil type 951
Default you already did something to the rear plate right?
not really in the location mentioned but thats the first thing to do. for me the vibration was so loud it was retarded. I used some packing foam and issue waw gone.
1988 Porsche 951: AKA Bad Idea
1991 Volvo 740T: AKA Solid Gold
Phil type 951 is offline   Reply With Quote
Old 01-09-2003, 05:48 AM   #3
HDClown
Default Your truck lock itself may be rattling
Then the license plate, than anything behind the interior panels. Lots of wires back there to bump up against the inside of your fenders.
Current: 2011 Audi S4
Past: 2006 VW GTI, 2002 BMW M5, 2003 BMW M3, 2001 Audi A4
HDClown is offline   Reply With Quote
Old 01-09-2003, 06:21 AM   #4
Ulilbastrd
Default Re: you already did something to the rear plate right?
yes, i put a piece of dyanamat behind it. any other ideas?
Casablanca White
Artic White
Ibis White
Old 01-09-2003, 06:23 AM   #5
A6_machine
Default My .02 cents..
My rear deck rattles. Mostly against the rear glass. Also I have three caps that have a belt symbol on them that shake around in their cut outs. For the glass I wedged four small black foam squares between the deck and the glass. For the caps I just used some black insulation strips 1/4 inch thick from Home Depot around the edge. Looks professional and didn't cost a lot. Other than the license plate ( almost impossible to stop rattling ) it sounds solid.
2000 A6 2.8Q
18" Techrome Helos Bezels
235/40/18 Kumho Ecstra Supra
2000 Kawasaki ZX12R
Micron Serpent Full System
Power Commander III ( dyno's @ 168rwhp )
( Makes up for the lack of speed and power with the 2.8!! )
A6_machine is offline   Reply With Quote
Old 01-29-2003, 07:06 PM   #6
sickq
Member
<HTML>
<embed src="http://members.fortunecity.com/muschi30/sounds/AustinPowers/groovy.wav" loop=false autoplay=false width=145 height=60></embed>
</HTML>
sickq is offline   Reply With Quote
Old 01-29-2003, 07:08 PM   #7
sickq
Member
<html>
<body>
</body></html>
annoying, rattle
HTML code is Off
