Old 10-13-2001, 09:10 AM   #1
OneEighth
Elder Member
Account #: 25172
Default FS: MTX 4300x and 225HO, Specs inside.. Prefer SoCal.
The scratches in the pics are visible cuz of flash otherwise, hardly noticeable.
Im thinking $300/~$400, 4300/225, or best offer.
Thunder225HO Amplifier
Low impedance, High-Output amplifier.
Individual gain controls for left and right.
2 sets of RCA connectors.
RMS Power measured at 12.5 Volts DC:
25 Watts x 2 into a 4 Ohm load with less than 0.05% Thd+N
50 Watts x 2 into a 2 Ohm load with less than 0.1% Thd+N
100 Watts x 2 into a 1 Ohm load with less than 0.3% Thd+N
200 Watts x 2 into a 1/2 Ohm load with less than 0.5% Thd+N
400 Watts bridged into a 1 Ohm load with less than 0.5% Thd+N
Dynamic Power (IHF-202 Std) measured at 14.4 Volts DC
65 Watts x 2 into a 4 Ohm load
120 Watts x 2 into a 2 Ohm load
200 Watts x 2 into a 1 Ohm load
370 Watts x 2 into a 1/2 Ohm load
700 Watts bridged into a 1 Ohm load
Signal to Noise Ratio:
> or =110dB A-Weighted
Damping Factor:
> 200
Frequency Response:
20Hz-20kHz ± 0.25dB
Dimensions:
13" x 9" x 2" (33cm x 22.8cm x 5cm)
14-1/4" x 9" x 2" (36.2cm x 22.8cm x 5cm) Including IsoFeet(TM)
and
Thunder4300x Amplifier
The front and rear crossovers are 18dB/octave, continuously variable between 50Hz and 200Hz high pass or low pass, giving you several options in setting up your system.
The new symmetrical power supply allows for better thermal distribution.
The "sum output" jacks on the four-channel amplifiers provide a line level summed output of the right front/right rear and left front/left rear input signals. This output is typically used to drive an external subwoofer amplifier.
37.5 Watts x 4 into a 4 Ohm load with less than 0.1% Thd+N
75 Watts x 4 into a 2 Ohm load with less than 0.3% Thd+N
150 Watts bridged x 2 into a 4 Ohm load with less than 0.3% Thd+N
85 Watts x 4 into a 4 Ohm load
140 Watts x 4 into a 2 Ohm load
280 Watts bridged x 2 into a 4 Ohm load
> or = 110dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-20kHz±0.25dB
Thunder EQ:
Variable Bass Boost (0-18dB) centered at 40Hz
Crossover:
Variable 50Hz to 200Hz, 18dB/Octave, High Pass or Low Pass Configurable
Dimensions:
OneEighth is offline   Reply With Quote
Old 10-13-2001, 09:19 AM   #2
OneEighth
Elder Member
Account #: 25172
Default And These
HTML code is Off
