Old 03-31-2000, 08:18 PM   #1
Rice Etr
Default Power amplifiers and your ECU..
When running the wiring for your aftermarket power amp form the battery, do not run it near the ECU. EMFi (Electro Magnetic Frequency interference) can cause the Knock Sensor Contro Unit inside the ECU to activate thus retarding the ignition timing which will result in a loss of power. This phenomenon is even more noticeable in cars with upgraded chips. If you have an unexplainable power loss, or fluctuations on your torque band or acceleration seems less that stellar, check to see where your power cable to the amp is running. If it is near the ECU, re-route it outside of the ECU's protective box...
Rice Etr is offline   Reply With Quote
Old 04-01-2000, 05:27 PM   #2
siberian
Default dude thanks for the warning! I'll consider that when I wire mine.
Don't ask, just accept it
siberian is offline   Reply With Quote
HTML code is Off
