Old 03-22-2000, 03:56 AM   #1
BobbyP
Default Replacing Factory Stereo
Hi all; I'm a new owner of a 99 A4 Avant TQ and I would like to replace part of the factory "Audi Concert" stereo with my Alpine Amp and BA speakers. Is it possible to leave the factory head unit and run the amp (basically, is there a line level out on the factory head unit?). I'm afraid the dash might not look right with the green lighting of my Alpine CD head unit- as well as the smaller size of the Alpine.
BobbyP is offline   Reply With Quote
Old 03-22-2000, 09:43 AM   #2
REF
Default I think you can change display to red,look it up in alpine manual
REF is offline   Reply With Quote
Old 03-22-2000, 11:34 AM   #3
Q
Q's Avatar
Default Re: Replacing Factory Stereo
as long as your amp will accept "speaker level" inputs
Upcoming Order
2012 S5 Prestige
Daytona Gray
Titanium Package
Drive Assist
Sport Diff
Stasis Challenge Package
HRE 560R 19x9.5
Nitto Invo 285/30/19
Audison Audio
In Garage
1996 Porsche Carrera 4S
2006 Mazda3s
2012 Volkswagen GTI
Q is offline   Reply With Quote
Old 03-22-2000, 04:23 PM   #4
John P.
Guest
Posts: n/a
Default NOT SO! The Concert unit has pin-outs that are TRUE signal level outs (tons of info inside)
Many have used this Blaupunkt adapter to connect to the Concert's wiring harness. It gives you front & rear RCAs (total of 2 sets) and an amplifier turn-on wire. With some Concert units, the adapter must be "tweaked" a little bit to fit. Most have found that it is plug'n play. Keep in mind that the Concert unit is made by Blaupunkt, hence the relationship between it and the part.
I repeat--you do not have to use a line level converter or use speaker-level inputs on your amp! In other words, you'll get a clean signal!
I ordered the part from Crutchfield (see link below) for under $9 (including 2nd day air). Keep in mind that Crutchfield's part # is different than Blaupunkt's. Since my TT isn't here yet, i haven't tried it myself. But many others have, successfully, such as Doug with his TT (check out his pictures, too--they show the harness installed):
http://www.albany.net/~doug/tt/equip.html
Visit the links below. I've assembled a TON of related info for your perusal:
http://www.audiworld.com/forum/m/tt/49833.phtml
http://www.audiworld.com/forum/m/a4/208039.phtml
http://www.audiworld.com/forum/m/tt/33903.phtml
Do me a favor, and let me know if this info helps. It took me a long time to research this stuff.
-John P.
Old 03-22-2000, 04:26 PM   #5
John P.
Guest
Posts: n/a
Default Crutchfield link didn't appear. Here it is . . .
http://www.crutchfield.com/cgi-bin/S...=S-HXwOg8yB74i
Old 03-22-2000, 04:41 PM   #6
avantster
Default What about the Symphony unit?
avantster is offline   Reply With Quote
Old 03-22-2000, 04:55 PM   #7
John P.
Guest
Posts: n/a
Default Re: What about the Symphony unit?
I can't say for sure--I've obsessed about the Concert unit because it is the only receiver getting TT duty.
However, I would imagine that there are preamp outputs of some sort in the wiring harness IF the Bose option uses an external amplifier (because it needs to get signal somehow).
-John P.
Old 03-23-2000, 01:56 AM   #8
uku
Default Great info John P, but have some questions on the concert unit
I have a A4 with a concert head unit non-bose.
Why does the CD changer that fits the Concert system a Panasonic if the head unit is a blaupunkt?
uku is offline   Reply With Quote
Old 03-23-2000, 08:04 AM   #9
BobbyP
Default Re: NOT SO! The Concert unit has pin-outs that are TRUE signal level outs (tons of info inside)
Thank you SO MUCH! The system goes in today (if they can get the adapter- otherwise I'll do it when I get it from Crutchfield)Now I can have a great system but have it look right and be at least somewhat stealthy. I very much appreciate your post!
Old 03-23-2000, 09:51 AM   #10
John P.
Guest
Posts: n/a
Default Great Question
I have no idea. I think Audi must've been shopping around for a good deal.
Also, it's standard procedure for an automaker to outsource particular parts (e.g., BMW does this with its alloy wheels) to several different manufacturers. I recall hearing that some Concert units are manufactured by another, non-Blaupunkt manufacturer. As long as the units conform to specs and are the right price, I'm willing to bet that Audi isn't too particular about the manufacturer. Additionally, Blaupunkt may not have have made a changer suitable for Audi's requirements.
-John P.
HTML code is Off
