Go Back   AudiWorld Forums » Audi Models » Audi A3 / S3 / RS3
Audi A3 / S3 / RS3 Discussion forum for the 8L and 8P Audi A3 S3 and RS3
Old 03-01-2000, 06:49 PM   #1
PPW
Default S3 with ESP
Has any driven a car with this product install. If so is it having???
PPW is offline   Reply With Quote
Old 03-05-2000, 10:48 AM   #2
andrew walker
Default Re: S3 with ESP
All S3's produced from January 2000 onwards will be fitted with ESP as standard. Whether the S3 really needs it or not is a matter of opinion but it is very much the same as a TT with a different shell. However, you can switch the ESP off by pressing the button on the dash so the choice will be yours anyway.
Andy.
andrew walker is offline   Reply With Quote
Old 03-05-2000, 11:58 AM   #3
PPW
The issue is that, when ESP is installed, it reqires changes to the spring's and shock's. So is an ESP with ESP disable a less enjoyable car to drive than a non-ESP car.
Old 03-05-2000, 05:19 PM   #4
Graham
The TT only requires the suspension retrofit as the ESP is calibrated to work with the revised suspension rates.
I think you will find the suspension on the S3 is unlatered with ESP as the ESP is claibrated to work with the standard S3 supsension when fitted to this car.
Graham is offline   Reply With Quote
Old 03-06-2000, 04:12 AM   #5
andrew walker
That would make sense Graham. I understand that the cost for fitting ESP to a TT is greater than fitting to an S3.
Andy.
Old 03-14-2000, 11:36 AM   #6
Wando
Junior Member
I drove an S4 with esp and it is not the best of systems, It drove much nicer switched off and that was is in heavy rain.
Wando is offline   Reply With Quote
