| Performance and Tuning Discussion forum for various performance tuning techniques and questions
Sponsored by CARiD |
#1 | ||
![]() 09' Quartz Grey A4 2.0T Quattro - APR - STaSiS - EuroCode |
#2 |
Banned
#3 |
when I did this on my drive by wire car I was getting a lean code. I think it was only lean during off boost loads, but lean enough to throw a code/CEL. How do your block 032 numbers look? Describe your plumbing like asked below.
Ray Khan 00 1.8T QM APR stage 3+ APR Exhaust APR Intake DUH FMIC Southbend OFE Stage 4 clutch SPEC 12 lb flywheel Greddy Profec B electronic boost controller Porshe Boxster calipers BIRA stage I brackets Hawk HPS brake pads A8 rotors, SS lines V&S Short Shifter Vogtland Coilovers Neuspeed 19mm rear sway 18x8 Flik Lex 235/40/18 Falken GRB 451 17x7.5 B5 S4 Avus 205/50/17 Dunlop Wintersport 3D Sony XM 7554 amp with 5.25" and 6.5" Infinity kappas MTX 801D amp with 2x10" kenwood sub enclosure Xenons Fog light relay mod VDO boost gauge in custom vent pod Clear corner mod S4 wheel well liner RS-4 grill AIM and MSN messenger:rakha77 |
#4 |
#5 |
Elder Member
Is that hose connected to the intake tube?
#6 |
Banned
#7 |
Elder Member
It doesn't do anything other then restrict how much air can flow thru it.
#8 |
I might try to put mine back in when I go back to venting to atmosphere and see if it prevents the lean code as my real one way valve did. I don't think it will work.
#9 |
Banned
the valve on the inlet tube isnt really a valve, its a damper...it allows flow both ways.
#10 |
| Tags |
| 20t, catch, vented |
