| Performance and Tuning Discussion forum for various performance tuning techniques and questions |
#1 | ||
Elder Member
#2 |
Elder Member
Why do you think your running over 100% on the second graph?
#3 |
Elder Member
#4 |
Audiworld Sponsor
Therefore, 20ms is 100% duty cycle at that RPM. If the specified pulse is longer than 20ms, then it just means that the injector is spraying through the full cycle (100%). You can't fit 35ms of spraying time into a 20ms cycle.
-Dave Pramanik |
#5 |
unless it detected overlean conditions and the whole system is backed off.
Having said that, how's your O2? was it lean before the swap? |
#6 |
Elder Member
02 voltages are fine, which is why this makes me wonder.
#7 |
Elder Member
Just found it funny that he said his injector duty cycle was over 130-140%, which I dont think can happen. If the injector was at 110% duty cycle at 6k rpms and the air flow was still increasing, the car would run lean in the higher rpms.
I guess a chart is needed to show how much ms at set rpms = 100% duty cycle. |
#8 |
Elder Member
#9 |
Audiworld Sponsor
From the RPM, you can calculate the time required for each revolution in milliseconds. Then double it for the time for the full cycle - 2 revolutions/4 strokes (intake, compression, ignition, exhaust).
Thats the maximum amount of time that the injectors can be open. Specifying a longer pulse width is pointless because you are into the next cycle (but tuners still do it). -Dave Pramanik |
#10 |
Elder Member
But would the car run lean if the duty cycle is over 100%? The reason I ask is because I had no problems holding 35ms readings even on my K03 and K04 setup at high rpms and the car never ran lean.
| Tags |
| cycle, duty, injector, s4 |
