Go Back   AudiWorld Forums » Technical Discussion » Performance and Tuning
Performance and Tuning Discussion forum for various performance tuning techniques and questions
Sponsored by CARiD
Click Here
Old 11-11-2000, 06:54 AM   #1
Leszek
Default Pictures of my A4 with rear A8L brakes.
Here are some pictures of my A8L rear brake upgrades:
Stock A4 rotor vs A8L rotor
A8L rear brake already mounted on the car
Side view
Behind the wheel
My front A8 brakes behind the wheel.
Leszek is offline   Reply With Quote
Old 11-11-2000, 03:00 PM   #2
Nogaro
Member
Default Re: Pictures of my A4 with rear A8L brakes.
Why did you chose Audi OEM stuff? Why not just buy aftermarket ones (stoptech, brembo..)? Is it because of the price? Or ease of install?
Nogaro is offline   Reply With Quote
Old 11-11-2000, 03:24 PM   #3
Leszek
Default Performance/Price ratio was the major reason...
There are other reasons as well:
1) Easy installation, everything bolts on.
2) You use your stock pads, which means they get replaced for free under warranty/maintenance.
3) Parking brake retained. You loose parking brake with most aftermarket solutions.
4) Both, front (312mm) and rear (269mm) A8 brakes fit under 16" stock sport wheels.
Old 11-12-2000, 07:41 AM   #4
flan
Default Re: Performance/Price ratio was the major reason...
How can you keep stock pads if rear rotor is 10mm thicker? And what about the mounting brackets- where did you get these- for the front or the rear?
Thanks
flan is offline   Reply With Quote
Old 11-12-2000, 08:49 AM   #5
Leszek
Default You keep the stock pads, but you change the caliper to accommodate the thicker rotor.
Old 11-12-2000, 08:56 AM   #6
Leszek
Default The bracket information I will release into the public domain if I will not market the kit.
Old 11-12-2000, 08:58 AM   #7
TOMT
Because you use different wider caliper.But rotor and pad contact surface remain the same.The bracket from audi by modify with mechining to make it fit A4 and S4 rear mounting point.
TOM T
TOMT is offline   Reply With Quote
a4, a8l
HTML code is Off
