| Performance and Tuning Discussion forum for various performance tuning techniques and questions |
#1 | ||
1998 B5 A4 2.0L Turbo 371.8KW (498.6HP)@ Wheels http://www.forums.vwvortex.com/zerothread?id=3195005&page=1 |
#2 |
chain sprocket to adjust the intake cams, but that is after you adjust the (adjustable if there is one) exhaust timing belt sprocket.
It really seems better if you can somehow adapt the adjusting chain tentioner found on the 2.8's and 2.7T's, and have variable intake timing or fix it to a more advanced position, no? Oh yes, for other folks, this is because the timing belt drives the exhaust cam and a chain connects the two together Heck, I just had another idea. You can have someone fabricate a chain tensioner such that you can slack the chain (top vs bottom) to provide more advanced position. Same effect as positioning an adjustable cam sprocket - for the intake at least. |
#3 |
Senior Member
timing by itself to compensate at different RPMS. This is what my tech told me. I am not sure, maybe he is a full of ****.
-Eric
The Beast Progress: 1.9L Forged Internals, Custom GT Turbo, Autronics Stand Alone, Twin Plate Clutch Turbo Pictures before Polishing Compressor Housing after Polishing Carbon Fiber Dash, JE pistons, SPA Tach, Knife Edged Crank, Polished Valve Cover Almost Done Custom Intercooler Custom Intercooler Installed w/ Piping |
#4 |
Junior Member
Lucas has an older car, only the 2001 has the variable valve timing. I forget which cam it moves, but it only has 2 positions.
Todd W |
#5 |
and has been pioneered and used in Porshe Boxters since their inception
#6 |
AudiWorld Expert
On My 1986 Coupe GT's KX motor!
Allowed one to adjust the powerband up or down the rpm range. Basically a "made for VW" item but fits Audi 10V cams.
![]() 2004 A4 1.8t USP Quattro 6MT K04-15/APR/TT 225 Injectors/Custom Stainless Exhaust/710N/RaceTec FMIC 034 HFC/Jet-Hot Cermi-coated & ported exhaust manifold Spec Stage 3+ with OE DMFW! Neuspeed TIP/Neuspeed Snub/Optima 75-35/AFE Pro-Dry/FSI Coils AMS Short-shift @ %40 redux(Sweet!) ST Coils/ H-Sport Anti-Sway bars/E-codes 19x8.5 OEM Audi Skinny Fives with 235-35 Bridgestone 760 Sport Skins B7 A4 brakes with StopTech Ceramic pads and Stop Tech rotors Sirius Satellite Radio Ross-Tech HEX-USB+CAN Equipped Escort 9500ix |
