| TT (Mk1) Discussion Discussion forum for the Mk1 Audi TT Coupe & Roadster produced from 2000-2006 |
#1 | ||
audi_pic5.jpg |
#2 |
Caveat: this is for a FWD car. If you need Quattro-specific, let me know
![]() 1 Phillips - head screw, 4 Nm 2 Brake disc Thickness: 9mm Wear limit: 7mm When worn, always replace both sides 3 Cap 4 Self-locking 12-point nut, 175 Nm Replace each time after removing 5 Wheel hub with wheel bearing and rotor Only replace complete Removing and installing: 6 Hexagon bolt, 60 Nm With dished spring 7 Splash plate 8 Stub axle 9 Handbrake cable Adjusting Hand brake, Refer to Park Brake System, Adjusting. 10 Axle beam 11 ABS speed sensor Before inserting sensor, clean fitting hole inner surface and coat with lubricating paste G 000 650 12 Hexagon socket head bolt, Tighten to 8 Nm 13 Hexagon socket head bolt, Tighten to 65 Nm 14 Brake carrier with guide pins and protective cap Supplied as replacement part assembled with sufficient grease on guide pins If protective caps or guide pins are damaged use repair kit. Use grease supplied to lubricate guide pins. 15 Brake hose/line With banjo bolt and seals Banjo bolt to brake caliper tightening torque 35 Nm Do not disconnect brake hose when changing brake pads 16 Self - locking hexagon bolt, Tighten to 35 Nm Replace 17 Brake caliper Servicing, Refer to Brake Caliper, Service and Repair. Adjust Hand brake cable first after maintenance or replacement CAUTION: The foot brake must not be operated first adjusting Hand brake, Refer to Park Brake System, Adjusting 18 Brake pads Thickness: 17 mm Checking thickness: Repair information, Maintenance Always replace both sides Always replace when changing pads
#3 |
audi_pic5.jpg |
#4 |
![]() Exploded view 1)Hex socket head bolt - 65 Nm 2)Brake carrier 3)Bolt - 35 Nm 4)Brake hose/line Tighten banjo bolt to 38 Nm 5)Brake caliper housing 6)Brake pads 7)Pad retaining springs Always replace when changing pads 8)Backing plate 9)Bolt -10 Nm 10)Brake disc 11)Phillips-head screw - 4 Nm 12)Wheel hub with rotor 13)Circlip 14)Wheel bearing 15)Trailing arm 16)Speed sensor 17)Hex head bolt 18)Parking brake cable
| Tags |
| 97, a4, a8, assembly, audi, brake, disc, exploded, hoses, names, part, quattro, rear, suspension, view |
