does any one know were the ecm or relay -J271 is located? thanks
Re: What problem are you trying to solve ?
car wont start i changed the camshaft position sensor and the other code is 17925 steve schwing says the bently manual states to check relay j271 -ecm. In a nut shell car won't start
Here it is.....
Check Motronic Engine Control Module (ECM) power supply relay -J271
The motronic Engine Control Module (ECM) power supply relay -J271- supplies voltage to the ignition coils with power output stages and the Engine Control Module (ECM) at pin 121. Disconnect voltage supply relay -2- below left cover at bulkhead.
Check fuse S10 (in fuse holder, position 10).
Note:
To remove the protective hood for the TT Roadster relay carrier, disengage at the bulkhead and swing downward. Disconnect additional harness connectors at Mass Air Flow (MAF) sensor, if necessary
Check Voltage between coil pak plug pins 1 and 4. should be approx. battery voltage (ignition on)
<img src="http://images7.fotki.com/v110/photos/7/7305/776256/coilpakplug-vi.gif">
Relay location (#2) is referred to as at the bulkhead...Might be in the engine compartment..Haven't looked:
<img src="http://images8.fotki.com/v111/photos/7/7305/776256/relay-vi.gif">
Note:
VorsprungTT
TT (Mk1) Discussion
11-26-2006 07:17 AM
Jon-1.8t
09-29-2004 10:17 AM
audittblu2
TT (Mk1) Discussion
09-24-2004 04:32 AM
