Why feel brake pedal hard sometimes ?( not after hard braking)
Old 04-08-2002, 12:49 AM
Levent's Avatar
Default Why feel brake pedal hard sometimes ?( not after hard braking)
Sometimes I feel like brakes hardened even in a city traffic.It feels almost like I've stopped the engine and braking ( not this much of course, but it is very obvious)and brake pedal comes to normal softness after a min. or so .
Also ESP light came on and I will go to service.
But this brake problem was there way before the light .
Any help will be very appriciated.
Old 04-08-2002, 03:12 AM
Elder Member
OTOF's Avatar
No clue, but have you had your brake fluid level checked out?
Old 04-08-2002, 03:23 AM
Elder Member
OTOF's Avatar
Default Also, brake fluid is supposed to be changed at 20k no matter
how long you've had the car...make sure that was done...think you have over 20k on your car ;-)
Old 04-08-2002, 04:06 AM
Levent's Avatar
Yes ,checked. Also it's still 18K km. in 1.5 years. Thank you.
Old 04-08-2002, 04:32 AM
Member
smallTTs's Avatar
Default Vacuum leak? It sounds like your brake booster is depleting or losing vacuum completely.
"Power brakes" use engine vacuum to increase the pedal force you apply. There is a check valve to prevent loss of the vacuum from the booster. If that leaks you should feel the pedal harden up as you hold it down. Remember, the engine is only producing intake manifold vacuum when NOT in a boost condition. Idle and closed throtle deceleration are highest vacuum conditions.
You could have a leak in the booster instead of the check valve. See the dealer about it in any case.
Old 04-08-2002, 04:41 AM
CraigsTT's Avatar
Default I noticed this the other night on my 2001 TTQC??
The pedal all of a sudden it felt very hard after its 'normal' softness. I have had other brake issues with the pedal going all the way to the floor and not coming back up in very cold weather. This problem has not been found or fixed by service and has occurred 3-4 times last winter. At the time I thought it was the brake booster perhaps this is another symptom of the same problem.
Old 04-08-2002, 04:59 AM
TTeleven's Avatar
Denny did interval change I thought it was 2 years never did the coupe at 20K
Old 04-08-2002, 05:27 AM
Elder Member
OTOF's Avatar
D'oh ... posted that before my morning coffee and got it backwards...2 years is correct.
Old 04-08-2002, 08:18 AM
Levent's Avatar
Great information. Thanks a lot.
Old 04-08-2002, 08:23 AM
Levent's Avatar
Default Thank you. I'll ask to the dealer. I don't feel they'll find the problem though.
Your problem is much frightening. Pedal going all the way down is not a nice feeling. :-(
Allan Gibbs
TT (Mk2) Discussion
04-22-2010 05:26 AM
nl01
03-22-2010 11:12 PM
alibaba
TT (Mk1) Discussion
11-18-2009 03:18 PM
Berserker
9
09-26-2008 10:36 AM
Merlin's S4
Audi Original "S" Cars
05-19-2008 06:55 AM
Quick Reply: Why feel brake pedal hard sometimes ?( not after hard braking)
