What are the advantages/disadvantages of 18" wheels over 17", what needs to be modified?
Old 04-06-2002, 04:11 PM
TT - Up's Avatar
Default What are the advantages/disadvantages of 18" wheels over 17", what needs to be modified?
Old 04-06-2002, 04:23 PM
TTeleven's Avatar
advantage looks and fit over big brakes - disadvantage cost
Old 04-06-2002, 04:26 PM
John P. (TT 225)'s Avatar
Default increased weight of larger wheels, more prone to pothole damage, degraded ride quality, but
damn they look better. :-)
Old 04-06-2002, 08:19 PM
Elder Member
Larrytt's Avatar
Default I can't think of a single advantage other than looks if you like a larger wheel
As John pointed out in almost all instances an 18" wheel will weigh more than a 17". The sidewalls will be shorter with a resulant stiffer/harsher ride. The costs are always higher, many shops might not be able to install 18" tires when you need new tires.
The diameter of the wheel has nothing to do with clearing larger brakes, only larger rotors. The calipers can have clearance issues with a 19 and 20" wheel, it is all about inner wheel curvature and the wheel offset.
The gap between the fender arch and the top of the tire will remain the same no matter what size wheels you use, the perception will only appear to be great with a larger diameter wheel because the tire sidewall is shorter. This is all based on you getting the correctly sized tire to keep your speedo accurate.
Old 04-07-2002, 05:50 AM
Member
Colonel Bogey's Avatar
Default Less tire wall deflection is only plus...negatives are covered below.
A profile that short on the street not only makes the ride racecar hard but increases likely hood of rim and tire damage on public roads. 18s that work on street were designed that way from ground up with higher profile tire incorporated in orginal design.
Old 04-07-2002, 08:04 AM
Member
smallTTs's Avatar
Listen to CB, Larry & John. They are right on target.
weeeeeeee
04-19-2003 05:23 PM
seattle audi
03-18-2002 04:25 PM
BluTTo
TT (Mk1) Discussion
02-24-2001 08:11 PM
Rich R.
02-16-2000 06:00 PM
nStokes
01-28-2000 05:38 PM
Quick Reply: What are the advantages/disadvantages of 18" wheels over 17", what needs to be modified?
