Side View Mirrors filled with liquid??!!??
My drivers side heated mirror got too hot and cracked at the edge. I guess and c. 2/3 of the liquid crap in it leaked out. I guess this is what makes it a $200 mirror.
Has this happened to anyone else?
I've had my mirrors turn brownish
inside on the edges. It started to work its way in towards the middle. Kinda seemed like a liquid pattern. I just bought the cheap replacement glass and slapped it over the old glass. Problem solved.
over the old glass? as in its place or as a cover?
one of my mirrors stopped heating and the other is showing a nasty yellow-to-brown gradient with condensation in it. Definitely liquid for the auto-dimming feature.
The replacement comes with
adhesive pads to stick the new mirror over the old mirror. I did not attempt to remove the old mirror as I would probably break something. The replacement mirror glass is surprisingly cheap. Just say goodbye to auto-dimming/heated.
Too expensive, i just fixed it...
Being sleep deprived from a newborn baby who doesn't sleep, i need to break something. So i got a shot at the mirror.
It was so bad i needed to removed the dimming film so that i could see something.
<img src="http://pictureposter.audiworld.com/68260/broken_dimming_mirror.jpg">
So i removed the mirror and found that it was leaking at the bottom, namely from a crack in the surrounding black plastic frame. I proceeded to remove the frame and then wanted to remove the plastic film over the mirror. I found out the hard way that it is a glass that covers the mirror and keeps the dimming liquid in there.
<img src="http://pictureposter.audiworld.com/68260/mirror_fixing_in_progress.jpg">
So it broke and i removed everything and cleaned the mirror. Now I have a simple, maybe heating, non auto-dimming for sure, mirror.
<img src="http://pictureposter.audiworld.com/68260/mirror_fixed.jpg">
Now I need to clean the contour but it'll be much more useful this way.
I need to find a true replacement, i like the auto-dimming feature.
Martin
Martin
