| A8 / S8 (D2 Platform) Discussion Discussion forum for the D2 Audi A8 and S8 produced from 1994-2002 |
#1 | ||
![]() 1997 A8 Quattro hot/cold 171,375 miles Tranny Dead! :-( Broken arm rest Broken cruise control (its a moot point now!) ![]() 2001 A8L Pearl White hot/cold Boss's Car (God She's Hot!) 87,774 miles |
#2 |
It's not the right one....Tozo will chime in I'm sure....I would see if the dealer has one and just go with that.
#3 |
#4 |
Senior Member
I think you have one filter turned 180 degrees from the other based on where the "out" side of the flow is (underneath in your picture). Obviously there are differences in the suction side depth as well as its location--compare it to where the "out" flow is side to side.
If you have the wrong filter, check your gasket too. One time I was sent a set from another place that was not for the right ZF tranny, and the gasket was wrong too--different pan shape. I noticed with the last blau set I bought, which was correct, that they seem to have sourced the filter separate from the gasket, so maybe they just got the filter wrong. Make sure you have and use the o ring for the filter too.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly VAG COM lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here; uprated fogs; other VAG COM tweaking to suit. Current #2: C5 '00 A6 4.2 ming blue w/ beige, new off showroom floor; Lemiwinks + VAG COM tweaks; smoked tails; RS 6 OEM 18's; RNS-D (CD) Navi On order: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery approx. 7/2013 Prior (each modded): '96 C4 A6 2.8Q, still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
#5 |
After his 97 tranny, he put in a 2000 tranny, and I think it had the filter you show there.....
If yours is a 97, it could have one of three type trannies, it's listed on audipages.com.....you need to get the one for your tranny. It won't work and damage would most likely occur. |
#6 |
Senior Member
For what it's worth, the one you say came out of your car looks like the one in my A6 4.2 that also uses the same 5HP24A tranny. And, blau sent me one that looks the same as the one I pulled in every dimension--suction height and location, general shape, thickness, bolt hole location, o ring/seal type, etc.
#7 |
![]() Join Date: Sep 2004
'05 Porsche Cayenne Turbo titanium on black '01black on black allroad 2.7T ---------------------------------------------------------------------- '01 black on black twin turbo S8 6 speed manual(euro TDI 6th gear), RNS-E, Passport SRX SOLD |
#8 |
the pickup pipe length changed over the years. Newer A8 has a 1/2" shorter pickup pipe.
#9 |
#10 |
Just joking.
| Tags |
| 5hp24a, blau, length, oem |
