Go Back   AudiWorld Forums » Audi Models » Audi A8 / S8 » A8 / S8 (D2 Platform) Discussion
Old 05-16-2006, 04:09 PM   #1
NODES
Default Car starts, but when put into any of the gears it does not move.
Starts and runs very quiet. The problem i have with it is, it goes into gear without any hassle but it does not move forward. Its like it stuck in Park. When i drained the Tranny fluid it only drained out 3 Qts. of oil and it smelled very bad and was almost black. When i put the car into gear 4th or D and rev it up over 2k the Indicators all light up (Safe Mode)
I have replaced the Tranny fluid today( but it only took 3 Quarts??? which is very low. Ive reset the tranny comp. and unhooked the battery for 30min. and still nothing.
What could i be missing?
ive got 3 codes come up on the VAG-COM
P0765 Shift Solenoid D Circuit Malfunction
P0100 MAF or VAF Circuit Malfunction
Incorrect gear ratio was the last code ive got.
NODES is offline   Reply With Quote
Old 05-16-2006, 04:40 PM   #2
marcodant
Junior Member
Default sounds bad, when the car is on do all the lights on the gear selection
on the dah light up like you are in all the gears at once?
97 a8q 4.2
Upgrades
painted lowers, TIPTRONIC conversion, rebuilt tranny, tranny code 0001, K&N air filter, cross drilled and slotted rotors ceramic pads, braided SS brake lines, euro clear corners, SS exhaust tips, Eibach springs, Bilstein shocks, cold weather package, fridge upgrade, moonroof (anyone else have one ?)
marcodant is offline   Reply With Quote
Old 05-16-2006, 04:52 PM   #3
tonypai
Junior Member
Default I think you are still short some tranny fluid. Should take 8-9 quarts.
HR Coilovers
LLtek Cold Air Intake
LLtek Exhaust
X Pipe
S8 Instrument Cluster
S8 Rear Sway bar
Parrot Bluetooth phone system
Rebuilt "Tozo" Transmission
tonypai is offline   Reply With Quote
Old 05-16-2006, 05:01 PM   #4
tozoM8
tozoM8's Avatar
Default Try it one more time.
If you change the filter, make sure that you have the correct filter!
'05 Porsche Cayenne Turbo titanium on black
'01black on black allroad 2.7T
'01 black on black twin turbo S8 6 speed manual(euro TDI 6th gear), RNS-E, Passport SRX SOLD
tozoM8 is offline   Reply With Quote
Old 05-16-2006, 05:35 PM   #5
Acceler8
Default *playing taps* your tranny is dead, at least it sounds that way
Anti Philthadelphia tourism BT
Founder
<a href="http://profile.mygamercard.net/A8sport">
</a>
Acceler8 is offline   Reply With Quote
Old 05-16-2006, 06:45 PM   #6
Jkay
Member
Default You only put in 3qts? That might be a problem; it needs 8-ish. Read the procedure 8(
18" 2006 Soft 5-Spokes - Goodyear F1s - Milltek Exhaust - Clear Sides &amp; Corners
Jkay is offline   Reply With Quote
Old 05-16-2006, 06:46 PM   #7
NODES
Default Re: sounds bad, when the car is on do all the lights on the gear selection
all shift indicators are on which is fine. The only time they get highlited is when i put it into any gear besides R and give it some throttle over 2K RPM.
The error i get is Gear ratio incorrect.
see to me it seems like the "pump is not pushing the liquid from the oil pan into the tranny, hence only the 3-4QTS of oil.
Old 05-16-2006, 06:48 PM   #8
NODES
Default Re: *playing taps* your tranny is dead, at least it sounds that way
Thx for the encouraging words
Problem is im in CANDA and these guys are rare, so getting any work done on my tranny is going to cost alot of pennies...
Old 05-16-2006, 06:54 PM   #9
Acceler8
Default sorry man. I just went through that ordeal about 3 months ago. not fun at all
Founder
</a>
Old 05-16-2006, 06:57 PM   #10
NODES
Default Re: You only put in 3qts? That might be a problem; it needs 8-ish. Read the procedure 8(
I have no problems with the procedure, its just that the Oild pan just spits it out if i try to put any more in....
ive left it in every gear for around 30-45sec. and then back again...something is not letting it circulate...
When you put it into gear, do u have to hold down the Brake after its in the gear? Not the handbrake, thats pulled.
car, move, starts
