Go Back   AudiWorld Forums » Audi Models » Audi A8 / S8 » A8 / S8 (D2 Platform) Discussion
Old 01-12-2006, 05:30 AM   #1
A 8
Default Left side Xenon light flickers and shuts down
Anyone experianced this and know what the problem is?
The light comes on again if I turn off/on the lights. Sometimes it then stays turned on and sometimes it shuts down agian after a minute or so.
/Michael
Black Pearl Audi A8 4.2Q -00
A 8 is offline   Reply With Quote
Old 01-12-2006, 05:36 AM   #2
PaulW
Default Almost certain: bad bulb
Mine did that.....the only real way to check it is to swap the bulbs from left to right....it's a PITA, but must be done.
Then replace both bulbs. Otherwise they won't match. Dealer price for a bulb: $175. You can buy a set on ebay for about $60 shipped.
If you don't change the 2nd one, it too will go out.
07 S8
PaulW is offline   Reply With Quote
Old 01-12-2006, 05:38 AM   #3
ZRock
Default Time for a new bulb (or pair of bulbs)
Mine was doing the exact same thing. Swapping sides verified that it was the bulb, not the socket, HID ballast, etc. I bought a pair on ebay, and replaced them both, figuring that if one was dying, the other was not far behind. I did keep the old (still good) one, just as a quick fix backup.
ZRock is offline   Reply With Quote
Old 01-12-2006, 05:47 AM   #4
A 8
Default Re: Left side Xenon light flickers and shuts down
Ok.
Time to do a bit of work then.
Thanks!
Old 01-12-2006, 07:25 AM   #5
Quattro 88 80
Default Exact same thing happened to me 2 weeks ago
Driver's side. With the car off and lights off I opened the hood looked for a connector going to the metal box behind the headlight and couldn't easily see one. I gently tapped on the box a few times and gave up thinking i would have to go to the Bentley.
Closeed the hood and haven;t had any problems with the lamp firing up since.
I know this isn't a fix or even the right way to do things, but I must have knocked whatever was interrupting the circuit free.
Quattro 88 80 is offline   Reply With Quote
Old 01-12-2006, 10:13 AM   #6
A 8
Default Re: Exact same thing happened to me 2 weeks ago
My problems actually started a year ago and I had a similar approach as you then, ie fiddeling with connectors etc and it would be fine for months.
Now it comes back within a few minutes to a day or so.
Old 01-12-2006, 10:21 AM   #7
A 8
Default Re: Almost certain: bad bulb
Paul,
I opened up the hood and tried to switch but it lookes very different compared to your pics. First there are no torx's, just a hatch that snaps off. The actual lamp dont seem to come off without dismantling the whole reflector unit.
I would take a picture and post if I knew how to get it in the post!?
/Michael
Old 01-12-2006, 01:27 PM   #8
Dan McBoost
Default The face lifts must be different. Ask the face lift people, or look up the Bentley info.
______________________________
Dan Mac
www.mcboost.com
Dan McBoost is offline   Reply With Quote
Old 01-13-2006, 05:08 AM   #9
A 8
Default Re: The face lifts must be different. Ask the face lift people, or look up the Bentley info.
I took out the whole assembly and took a closer look, it is very simple. You just press and turn and the lamp will come free.
2001, a8, audi, circuit, flickers, intermittently, light, ps3, shut, shuts, xenon
