| A8 / S8 (D2 Platform) Discussion Discussion forum for the D2 Audi A8 and S8 produced from 1994-2002 |
#1 | ||
2005 Audi A8L 2000 A8, silver/blk, all options |
#2 |
Member
then it's probably low A/C charge. This causes one side to be warm and the other cold.
If you have the CLICK then one of your damper vane actuation motors is toast and you must use VAGCOM to find out which one, then replace it.
------------------------------------- ![]() 18" 2006 Soft 5-Spokes - Goodyear F1s - Milltek Exhaust - Clear Sides & Corners |
#3 |
it must be another one. I'll post the codes
tomorrow.
#4 |
But every time this comes up, I'm always wrong.....ttuling posted about this....so did Jack who originally had the problem I think.
On the safe side, check the fuses. |
#5 |
#6 |
Junior Member
if so.. it's just feron level that is LOW... mine was doing the same thing and i just had it recharged ($120 with diagnostic) and it's blowing very cold now.
------------------------------ 1999 A8 Pearl White "I am what I am......" ------------------------------ |
#7 |
Has anyone found a resolution to this issue? I have a 2004 A6 4.2. Several times recently, after driving for 30 minutes or so with the A/C on, heat will start pounding from the driver's side vent. Can't get it to stop.
Outside air temp was around 85 degrees, A/C set to 72ish. Once, the heat was coming out of the left center vent too. Other times it was just the driver's vent by the door. Anyone find out what causes this? Bill |
