| A8 / S8 (D2 Platform) Discussion Discussion forum for the D2 Audi A8 and S8 produced from 1994-2002 |
#1 | ||
#2 |
#3 |
But right now I have my track tires mounted.....going for a shake down cruise!!!!!
#4 |
at least it is fairly equal side to side so that you don't have to mess around shifting the subframe. I looked online for adjustable upper arms for the A8 and didn't have any luck locating them.
working on a new sig.... |
#5 |
#6 |
#7 |
look into fabricating billet upper control arms with adjustable threaded ends like the tierods?
Gone: ![]() Now: ![]() <a href="http://pictureposter.audiworld.com/77296/100_0270t.jpg"> My custom paddle shifter</a> <a href="http://forums.audiworld.com/a8/msgs/128171.phtml"> * Washer Fluid Sensor Fix</a> <a href="http://forums.audiworld.com/a8/msgs/104786.phtml"> Memory Seat Set Procedure</a> Current Rides: 2005 BMW 525i - 18" Polished Breyton Flame Wheels Past Rides: 02 S2000 New Formula Red/Blk 97 A8Q Pearl/Blk ..201K miles! 98 S70 Teal/Tan here was a rough transition : -) 92 300zx Black/Tan 92 240sx Juniper Grn/Tan 89 Probe GT (first car) White/Red (yuck!)
#8 |
the inside of your tires over the long haul. It will be a smooth wear but with those camber readings, you should have good turn in.
2005 A8L W12. Alpine MRXM 55 Mono Amp, JL Audio 12W3V3 Sub, K&N air filters, and cross drilled rotors. |
#9 |
... camber kits, but none for the A8. it may be possible, but since there are two seperate upper control arms, and they pivot differently when turning I'm not sure how that would work out...
#10 |
pivot points per side with adjusting for funky x/y/z parallel movement and the camber correction. If not adjusted properly, it might give a bad combination of camber/caster angle. I don't think I want to attack this ;-) I don't have the ambition to breaking out the 'ol TI92.
| Tags |
| 03, 07, alignment, camber, frontleft, frontright |
