Go Back   AudiWorld Forums » Audi Models » Audi A8 / S8 » A8 / S8 (D2 Platform) Discussion
Old 01-09-2005, 06:27 AM   #1
SILVER1
Default a8 -97 dashboard Cluster Dimmer Lightbulbs?
Hi Folks
A helping hand is needed/
The lights in the instrument cluster will no longer dim or brighten from about 5 days ago. Only the standard background red light remain.
I have taken out the cluster and could see 3 x bulb in orange holders & holder and 1 x in black holder. Would I be right in assuming one or all of these need changing or is there something else that I have missed.
I am certain this has been covered on the forum but just can't find it. Has anyone got a picture showing the same?
Appreciate you help and knowledge. Thanks
SILVER1 is offline   Reply With Quote
Old 01-09-2005, 09:37 AM   #2
skiracer
Default If they all went out at the same time, I would suspect a fuse or other electrical fault.....
I is possible that all three went out at the same time, but not likely. Do the lights in the HVAC and Radio control heads dim when you dim the instrument cluster light switch? They are connected together. If the HVAC or Radio heads don't work either, then you have a bad dimmer switch, wire, connector, or fuse.
skiracer is offline   Reply With Quote
100, 97, audi, dashboard, dim, dimmer
