Windshield Washer - low pressure? leaks?
Old 11-22-2004, 01:18 PM
bowster's Avatar
Default Windshield Washer - low pressure? leaks?
Anyone have leaks/problems with the windshield, squirt/spray system?
Mine empties after 4/5 uses and can barely squirt 5" up onto the windshield.....
I'm 'going in' this weekend, any help is appreciated.
I'll document what I find and post...
Mark
2001 A8L
Old 11-22-2004, 01:23 PM
KaMaKaZieP -ALUMIN8-'s Avatar
Default Sounds like a loose connection.
You may have a leak next to the washer pump. The pump has 2 outputs. 1 for the windshield, and 1 for the headlights.
Do you notice any large puddles of water under the car immediately after you spray?
ex-a8drifter's Avatar
Default Mine doesn't have problems, but that sounds like a leak.
maybe a small one that prohibits the full pressure? Are there puddles on the ground after use?
Old 11-22-2004, 01:24 PM
skiracer's Avatar
Default The reservoir holds over 2 gallons- if you're only getting 4-5 uses, then.....
the rest is disappearing onto the ground somewhere. A common leak point is at the headlamp washers and the plumbing leading to them. I'd check there first. Also, there should be some indication of wherer it is leaking by the spots on the ground.
Old 11-22-2004, 01:34 PM
Mitaka's Avatar
Default I had this problem. It was an easy fix
Open the hood. There is a connector that comes loose. It is located under the windshiels on the passenger side. Make someone else sprays the windshield while you inspect where the leak is. You should see the water gushiung a lot of it.
Old 11-22-2004, 01:38 PM
PaulW's Avatar
Default Correct, go to the audipages.com timing front end procedure for pics
<ul><li><a href="http://www.audipages.com/Tech_Articles/Body/frontendremoval.html">http://www.audipages.com/Tech_Articles/Body/frontendremoval.html</a</li></ul>
Old 11-22-2004, 01:53 PM
bowster's Avatar
Default Re: Windshield Washer - low pressure? leaks?
What an incredible response rate!
5 replies in less than 20 minutes...
This Forum Rocks (This should be the default A8 forum, not the D3!! ...from link in header)
Anyway, I haven't done any trouble shooting yet and I'll be too busy until Friday.
I'll report back this weekend...
Thanks to all...
Old 11-22-2004, 02:40 PM
Junior Member
badmyan's Avatar
Default There was also an issue with the bottle leaking where the pump attached on some Audi's
I had one of mine replaced for this reason. The leak is very easy to see.
Old 11-29-2004, 12:09 PM
bowster's Avatar
Problem solved....
One of the flex lines came loose, easy to spot, easy to fix.....
Thanks for the help!
SGT Stig
05-29-2018 05:13 AM
AudiGman
Audi 100 / A6 (C4 Platform)
12-28-2007 02:25 PM
kshawn126
11
12-14-2005 07:54 AM
husky
09-14-2003 08:34 AM
Quick Reply: Windshield Washer - low pressure? leaks?
